Tip & How-To about Computers & Internet
Slow PC Bootup 1. Clear windows prefetch start > run > %windir%prefetch delete all items in folder (this will clear windows prefetch directory). 2. Clear windows temp files start > run > enter %temp% press enter (delete all files in directory). 3. Download and install bootvis.exe tool used to optimize bootup performance. Microsoft tool called Bootvis "Click here to download" 4. Open bootvis go to Trace > Optimize System
Computers & Internet Logo
slow
windows xp
start > run > type in " %temp" and click ok . delete the contents of the folder Also start > run > type in c:\windows\prefetch , clear the contents of the folder
If it is windows 7 / Vista just hit the windows key ( the key with windows flag on the right side bottom , in between ctrl and alt key ) and perform the above .
Also detele the cookies and temp files on your internet explorer or whatever browser ( tools options)
Aug 04, 2011 | Acer Aspire 5315 Notebook
tuneup utilities prefetch data deleted windows 7 slow
I'm getting the Prefetch Data Deleted 'problem' on my tuneup 10 - it's telling me that because the prefetch is empty...yes...but my register is telling me both the Prefetch and Superfetch are set to '3' which is the correct, or default, setting for the feature. There is a program deleting my prefetch data and I want to find which one it is. Opera browser collects application data for offline work, I disabled this cache, and still I get the message from tuneup. Any other programs or browsers I can check?
May 25, 2011 | Microsoft Windows 7 Ultimate for PC
Speed Up Windows XP in 5 Steps
Nice tips! You can press SHIFT-DELETE though so you wouldn't be going to the recycle bin to empty it.
Dec 09, 2010 | Computers & Internet
How to clear Prefetch
go to start
type prefetch
delete the contents
May 03, 2010 | HP Pavilion dv6000z Notebook
It runs really slow and will freeze up. Ran a virus scan and nothing shows up. Ran clean up a defragment and upgraded the memory. nothing works.
YOU CAN PERFORM A FEW MORE STEPS
Manually delete cookie files in Internet Explorer 6 1. Exit Internet Explorer 6, and then exit any instances of Windows Explorer. 2. Click Start, click Run, type inetcpl.cpl, and then press ENTER. 3. On the General tab, click Delete Cookies in the Internet Properties dialog box, under Temporary Internet Files. 4. In the Delete Files dialog box, click to select the Delete all offline content check box, and then click OK.
RUN DISK CLEANUP
DELETE TEMP FILES
1. Click on Start and then Run.
2. In the text box in the Run window, type %Temp% and click OK. A folder full of files and other folders will appear.
3 All of the folders and files you see in this Temp folder are no longer being used by Windows XP and can safely be deleted.
4. To remove individual folders or files, hold down your Ctrl key while left-clicking on each item you want delete. Release the Ctrl key when you're finished.
5. To delete these items, hit your Delete key or choose File and then Delete from the menu.
6. Confirm that you want to delete the files by clicking Yes on the Confirm Multiple File Delete window that opens.
7. To remove everything inside the Temp folder, choose Edit and then Select All from the menu. 8. Now that all of the files and folders are selected, hit your Delete key or choose File and then Delete from the menu.
9. Confirm that you want to delete the files by clicking Yes on the Confirm Multiple File Delete window that opens. 10. After all of the files have been deleted
DELETE PREFETCH
2. In the text box in the Run window, type “Prefetch” and click OK. A folder full of files and other folders will appear.
3 All of the folders and files you see in this Prefetch folder , Remove them.
9. Confirm that you want to delete the files by clicking Yes on the Confirm Multiple File Delete window that opens. 10. After all of the files have been deleted you can close the window and empty your Recycle Bin, permanently removing the files from your PC.
Note: If you are unable to clean up the Prefetch files follow these steps to remove the Prefetcher from the registry residual
Download Revo Uninstaller: http://www.revouninstaller.com/download/revosetup.exe
AND REMOVE UNWANTED PROGRAMS
DOWNLOAD CCLEANER CCleaner can be downloaded from http://www.ccleaner.com/ AND RUN IT
CREATE A NEW USER ACCOUNT
Jan 31, 2010 | HP Compaq Presario SR1602HM (CPQSR1602HM)...
136 people viewed this tip
David Payne
David Payne
