After logging on there is no desktop, task bar, system tray or side bar. Instead you are left with a totally black screen and a single My Computer Explorer window. Even this window might be minimized making it hard to see. 1. Restart the Computer and login with the login and password that you use.
2. If the black screen appears and there is no icon visible on screen, Press the “ALT + CTRL + DEL” keys on the keyboard together.
3. A windows will appear with option to launch Task Manager, Simply Launch Task Manager.
4. On Task Manager, go to Application Tab and Click on New Task
5. Now type "explorer.exe" in the task window and click run.
It sounds like explorer.exe is being turned off. When you log in to Safe Mode hit Ctl+Alt+Del to bring the Task Manager and see if explorer.exe is running under Processes. If not, you can go to the Applications tab in Task Manager and click the New Task button and simply type in explorer.exe. If this does not give you your Start Menu and Task Bar then you need to take your computer back to the repair service and have them fix it properly this time. Otherwise, you'll have to reinstall the operating system.
Right click on the task bar (I assume you mean the bar that is typically at the bottom of your desktop?) Make sure "Lock the Task bar" is not checked Click on the border of the task bar drag directly from where you clicked to the bottom Adjust height accordingly
We wish you a merry Christmas and a Happy New Year.
Which is the operating system? What exactly happens when you start the PC? Is it Blinking cursor with a black screen?
Then its black screen error.
Firstly, there appears to be many causes of the black screen issue.
The symptoms are very distinctive and troublesome. After starting your
Windows 7, Vista, XP, NT, W2K, W2K3 or W2K8 PC or server the system
appears normal. However, after logging on there is no desktop, task bar,
If you have these symptoms you can safely try this for free Black
Screen Fix. It will fix the most common cause we have seen of this
issue. Running the fix program is easy under normal circumstances,
simply download with your browser using the link above and run the
program. However, if you are trying to do this from the PC which has the
black screen it is a bit more tricky. In these circumstances follow the
procedure below:
1) Restart your PC
2) Logon and wait for the black screen to appear
3) Make sure your PC should be able to connect to the internet (black
screen does not appear to affect this)
4) Press the CTRL, ALT and DEL keys simultaneously
Note this command assumes that you are using internet explorer as your
browser, if not substitute your browser path and file details for those
of iexplore.exe or use the Browser option of Task manager to locate it.
9) Click OK and your browser should start up and begin the download
process
10) When prompted for the download Click run, the black screen fix
program will download and run to automatically fix the issue.
11) Now restart your PC and the black screen problem will hopefully be
gone.
Firstly, there appears to be many causes of the black screen issue. The symptoms are very distinctive and troublesome. After starting your Windows 7, Vista, XP, NT, W2K, W2K3 or W2K8 PC or server the system appears normal. However, after logging on there is no desktop, task bar, system tray or side bar. Instead you are left with a totally black screen and a single My Computer Explorer window. Even this window might be minimized making it hard to see.
If you have these symptoms you can safely try our free Black Screen Fix. It will fix the most common cause we have seen of this issue. Running the fix program is easy under normal circumstances, simply download with your browser using the link above and run the program. However, if you are trying to do this from the PC which has the black screen it is a bit more tricky. In these circumstances follow the procedure below:
1) Restart your PC
3) Make sure your PC should be able to connect to the internet (black screen does not appear to affect this)
5) When prompted, Click Start Task Manager
6) In Task Manager Click on the Application Tab
7) Next Click New Task
8) Now enter the command:
"C:\Program Files\Internet Explorer\iexplore.exe" "http://info.prevx.com/download.asp?GRAB=BLACKSCREENFIX"
Note this command assumes that you are using internet explorer as your browser, if not substitute your browser path and file details for those of iexplore.exe or use the Browser option of Task manager to locate it.
9) Click OK and your browser should start up and begin the download process
10) When prompted for the download Click run, the black screen fix program will download and run to automatically fix the issue.
11) Now restart your PC and the black screen problem will hopefully be gone.
