Tip & How-To about Washing Machines
Whirlpool / Kenmore Washer - Drive Block
Whirlpool / Kenmore Top Load, Direct Drive Washers.
A number of the diagnostics and repair procedures for these washers require you to remove the agitator(s).
In order to get the agitators out, you need to remove the "Spanner Nut" and "Drive Block".
Many instructions call for a special spanner wrench to remove the nut.
However,
You don't need a special spanner wrench. (About $20 retail)
I've used a short 10" pipe wrench (About $9 also good for cracking walnuts) hooked around one of the tabs on the spanner nut and tapped the handle with a hammer to loosen it.
Also, don't directly hit the drive block with a hammer (it's soft metal). Put a short piece of wood under the drive block and tap it up with a hammer.
Washing Machines Logo
how, can I clean the washer. I washed many time my husband dirty coverols and now its effects my washings.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
KENMORE top load, direct drive, neutral drain washers are made by Whirlpool.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
The best way to completely clean the washer is to pull the agitators and drum in order to get to the tub.
Following is the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Following is a description of how to remove the cabinet, pump, motor, transmission and basket drive tube on Whirlpool / Kenmore / Roper direct drive washers.
As an aside, you don't need a special spanner wrench to remove the spanner nut. I've found that a short (10") pipe wrench hooked over one of the spanner nut tabs and tapped with a hammer will usually loosen the nut. Also, rather than hitting the Drive block directly with a hammer, put a short piece of wood under it first to protect it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Jun 19, 2010 | Kenmore 24032\24036 Top Load Washer
My washer
Then see the Whirlpool / Kenmore Service Manual for top load, direct drive washers. It has troubleshooting and testing procedures. AND, in particular, if this is a basic top load machine, specific instructions for how to remove the timer. (There are two types with different procedures.) I'd go through the testing procedures before assuming that the timer is bad though.
May 05, 2010 | Kenmore 24032\24036 Top Load Washer
My washer won't stop running.
This sounds like a Timer problem. See the following Whirlpool / Kenmore Service Manual for top load / direct drive washers. It has a troubleshooting section and test procedures.
Apr 06, 2010 | Kenmore 24032\24036 Top Load Washer
leaking water from underside.Think it is the seal. Kenmore elite top washer 22032100 (118) How do you get the tub out? Thanks Bob
Assuming that you have a basic Whirlpool / Kenmore top load direct drive washer (prefix 110) see the following Sears Parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22032100
Following is an illustrated description of how to pull the agitators, pump, transmission and tub.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=3c7e8512ce834388040aec95dcdb0a56
NOTE:
Many instructions call for a special spanner wrench to remove the nut. However,
Jan 04, 2010 | Kenmore 24902 Top Load Washer
Where can I find a repair instucton manual for a kenmore series 90 washer?
Following is the Whirlpool / Kenmore installation and service manual for top load, direct drive washers.
Following is the Whirlpool / Kenmore parts list for commercial washers although the consumer model is basically the same.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Oct 18, 2009 | Kenmore Washing Machines
284 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
