Tip & How-To about Computers & Internet
How To: Change Your Ip In Less Then 1 Minute
1. Click on "Start" in the bottom left hand corner of screen
2. Click on "Run"
3. Type in "command" and hit ok
You should now be at an MSDOS prompt screen.
4. Type "ipconfig /release" just like that, and hit "enter"
5. Type "exit" and leave the prompt
6. Right-click on "Network Places" or "My Network Places" on your desktop.
7. Click on "properties"
You should now be on a screen with something titled "Local Area Connection", or something close to that, and, if you have a network hooked up, all of your other networks.
8. Right click on "Local Area Connection" and click "properties"
9. Double-click on the "Internet Protocol (TCP/IP)" from the list under the "General" tab
10. Click on "Use the following IP address" under the "General" tab
11. Create an IP address (It doesn't matter what it is. I just type 1 and 2 until i fill the area up).
12. Press "Tab" and it should automatically fill in the "Subnet Mask" section with default numbers.
13. Hit the "Ok" button here
14. Hit the "Ok" button again
You should now be back to the "Local Area Connection" screen.
15. Right-click back on "Local Area Connection" and go to properties again.
16. Go back to the "TCP/IP" settings
17. This time, select "Obtain an IP address automatically"
tongue.gif 18. Hit "Ok"
19. Hit "Ok" again
20. You now have a new IP address
With a little practice, you can easily get this process down to 15 seconds.
P.S:
This only changes your dynamic IP address, not your ISP/IP address. If you plan on hacking a website with this trick be extremely careful, because if they try a little, they can trace it back
Computers & Internet Logo
Can't connect to the internet with router
1.Powercycle equipment ( Unplug power wait 15 seconds then plug back in. 2.Make sure connections are tight in to the router and to the modem. 3.Check you network settings Windows XP: Start/Run/Type ncpa.cpl and hit ok. Check and make sure that your connection doesnt say Connected Firewalled if it does to the left hand side you will see change windows firewall settings turn to off.If it doesnt say that double click the connection hit properties click on internet protocol and hit properties again,ensure that obtain ipaddress automatically is checked as well as obtain dns server automatically If not check them both and restart your computer. Windows Vista/7 Start/Search bar type ncpa.cpl right click on your connection and hit properties uncheck ipv6 and click on ipv4 and hit properties. After Ensure obtain ip address automatically is checked as well as Obtain DNS server automatically is checked restart computer. 4.Use command prompt: WIndows XP: Start/Run/Type cmd and hit ok Windows Vista/7 Start/All Programs/Accessories/Right Click Command Prompt and hit run as administrator. 5.Type in Command Prompt the Following Commands Each line is a seperate line is a new command simply press enter after each. netsh int ip reset reset.log netsh int ip delete arpcache netsh winsock reset ipconfig /flushdns 6.Restart Computer Final: If you still have issues connecting refer to router manufacture.
Jan 12, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
FOR TOP SOLUTION VISIT MY BLOG. demon-qwerty.blogspot.com
Jan 06, 2010 | Computers & Internet
wount stay connected when i click on the net it goes off
1.Powercycle your equipment (Unplug the power for 15 seconds then plug back in)
2.Ensure Ethernet cords are plugged in tight.
3.Open Network Connections XP:Start/Run/Type ncpa.cpl hit ok
Vista/7 Start/Search Bar/Type ncpa.cpl
4.Right click on Wireless connection (Router) hit properties
5.Uncheck Internet Protocol Version 6 /Click on Internet Protocol Version 4 and hit Properties.
6.Ensure obtain ip address is marked as Automatic
Ensure obtain DNS servic is marked as Automatic if not check both boxes and close out
7.Disable Firewalls XP:Start/Control Panel/Switch to classic view/Windows Firewall/Turn off
you can access the firewall through control panel with Vista/7
8.Open Command Prompt Windows XP:Start/Run/Type cmd hit ok
Vista/7 Start/All Programs/Accessories/Right click on Command Prompt and hit Run as Administrator.
9.Type: netsh int ip reset reset.log Hit Enter after each Command
Type: netsh int ip delete arpcache
Type: netsh winsock reset
Type: ipconfig /flushdns
10.Restart the computer if this does not work update the Firmware on your router to do so:
Open Browser in address bar type 192.168.2.1 this will bring you to your routers configuration bottom left hand side (Update Filmware) if you are still having issues with it disconnecting refer to Manufactorer
Nov 23, 2010 | Belkin Basic Wireless Router
Can I program this hub to provide a route to 192.168.1.102? (One computer in my group must have this specific address to stay connected.) I have a linksys WRT54G wireless router that is beyond my ability to set up with a static address. I called their tech support and they said they could do it, but that it was beyond the scope of their service to explain such a complicated process so I guess I'm out to buy different equipment. I can't set it up and they can't explain over the phone how to set it up. I saw the D-Link 12 port ethernet hub for sale and thought I might just run CAT 5 cable to everything... forget the wireless .... but I'd really like to verify that by doing so, that I'll be able to provide that one computer with the 192.168.1.102 address that it is needing.
OK the address that ya need is set in the PC's network adapter settings.
2. Click on "Run"
7. Click on "properties" You should now be on a screen with something titled "Local Area Connection", or something close to that, and, if you have a network hooked up, all of your other networks.
11. Create an IP address 192.168.1.102
12. Press "Tab" and it should automatically fill in the "Subnet Mask" section with default numbers. 255
This should sort out ya setting ya IP.
Jan 20, 2010 | D-Link DE 812TP (DE-812TP+) Networking Hub
HOW TO ACESS MSDOS IN MY LAPTOP
Depending on the operating system installed, you can get to a DOS like environment.
  1. In Windows XP, Start, run Type CMD Click OK
  2. In Windows Vista/Windows 7, on the search line type CMD, right click Command Prompt on the Menu above, Click Run as Administrator, Click Accept on UAC prompt.
  3. In Windows 98/Millennium, Start, Run, COMMAND, OK
Dec 27, 2009 | ASUS Eee PC 1000H Laptop
279 people viewed this tip
David Payne
David Payne
