Tip & How-To about Plumbing
Save hundreds of dollars each year with this simple water saving tip!
We all read lots of tips when it comes to saving water....but this tip is probably the best kept secret in the water saving arena!! Whenever you are preparing the water for a shower begin by turning the hot water on full and leaving the cold water completely off UNTIL the hot water begins to flow. THEN add the cold into the mix. Other wise, you send hundreds of gallons of cold water down the drain if you begin by letting a mixture of hot and cold run until it finally gets hot. WHY is this the case. Because, the hot water sitting in the hot water pipe cools off over time. The only way to actually get the hot water to the spout is to displace all of the cooled off water out of the hot water pipe until the hot water starts to flow again!
Plumbing Logo
What are the necessary tips of moving???
Consult with removals companies, and I also recommend you to hire services of removals company because they are very help ful in avoiding any damage,
Removals Surrey
Dec 21, 2012 | Perfect Optimization 101 Tips On Search...
Nowdays i am using N8 mobile set. But Today while i was Saving the confugration for net connection. It was hang still . What is the problem ? and what can i do to fix this problem ?
Reset your phone by using secret code you can find the secret code in twilightwap.com>phone arena>mobile zone
>secret codes>nokia
Aug 03, 2011 | Nokia N8 Cell Phone
368 people viewed this tip
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
