Tip & How-To about Computers & Internet
Solution for Most common blue screen error of windows.
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Computers & Internet Logo
i get a blue screen on my compaq presario what could it be
Then press any key.
Then type "y"
Jun 28, 2011 | Compaq Presario 5000 PC Desktop
few minutes after Windows starts the computer screen shows this blue screen with lots of white text and then it shuts itself off, then it restarts itself and then again, the blue screen and it shuts itself off. We can not use it. Can you help?
Then press any key.
Then type "y"
Jun 21, 2011 | Toshiba Tecra M2V-S310 Notebook
blue screen problem in my computer.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system. Also this error comes when there is bed indexing unit in hard drive. You can solve this errors with following 2 methods. (1)When you power up the computer press F8 key then enter in safe mode. Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error. (2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk. Boot your computer with that disk For that when you power up the computer press F1 or F2 "del" key to enter in bios. Then go to boot menu and set first boot device as your cd or dvd rom. Then save settings and exit bios. Insert windows disk in cd /dvd rom. Then it boot with that disk.Then you get this message "Press any key to boot from cd.." Then press any key. Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r" Then type "y" Then it fix error on hard drive. Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows. Thanks for using FixYa.
Nov 11, 2010 | HP Officejet 5610 All-In-One InkJet...
windows xp quit loading blue screen says page-fault-in-nonpaged-area tech info ***stop:0x00000050(oxc9464269,0x00000000,0x870e208c,0x00000000)
Then go to boot menu and set frist boot device as your cd or dvd rom.
Then press any key.
Then type "y"
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windwos " then it repairs old windows then it loads again old windows.
Jan 08, 2010 | Microsoft Windows XP Home Edition
Windows XP will not start on Inspiron 1300. Get blue screen with the following codes. 0x00000024 (0X001902FE, 0XF88F53D4, OXF88F50D0, 0X828AE805)
Then press any key.
Then type "y"
Dec 18, 2009 | Dell Inspiron 1300 Notebook
826 people viewed this tip
David Payne
David Payne
