Tip & How-To about Computers & Internet
Barcode scanner reapir tips
Loading Scanner: With the scanner powered off press and hold the SHIFT key & BK SP key on the scanner. While holding those two keys down press power, let power key go and then let SHIFT and BK SP go. The scanner will now go thru a reboot process. When done the scanner should read:
“ COMMAND MODE “
Select function
Self Test
At this point press the up arrow key twice and the scanner will now read:
“ COMMAND MODE “
Select function
Program loader
Place the scanner in the cradle and press enter. The scanner may or may not give a message saying “ WARNING: EEPROM WILL BE ERASED CONTINUE? “ At this point push enter. Let it erase the EEPROM. When done the scanner will ask you for “BAUD” press the up arrow twice and the scanner should read 38400. Press enter and, the scanner will ask you for “data bits”, press the up arrow key for 8 bits. The scanner will now prompt you for “flow control”, press enter. The scanner will now be on a screen that says:
“COMM Parameters”
Start?
Just leave the scanner at that screen for now.
There is a file you need to test its called Diags.hex that needs to be transferred to the unit. once that is downloaded you can test the laser memory and even the keyboard.
Computers & Internet Logo
how do i reset radio shack pro 83 scanner back to factory settings
With the scanner off, press and hold the 2, 9, and HOLD keys. While still holding them down, power on the scanner. Continue to hold the 2, 9, and HOLD keys until the display says CLEAR.
May 04, 2014 | Radio Shack Pro-83 Scanner
power butoon works and the others seem not to function
Is the display showing an icon that looks like a key? If so, you have unintentionally locked the keyboard. To UNLOCK it, power the scanner ON and then press the FUNC and key (picture) keys. If that doesn't work you will need to RESET the scanner. To do this, power the scanner OFF, then press and hold the 2, 9, and HOLD keys while you power the scanner ON. The RESET will erase all your programming, but it will get the unit working again.
Bill B.
Listening in since the 60's
Jun 25, 2011 | Uniden BC92XLT Handheld Scanner
how do i rest
Instructions
  1. PDT 3100 21 Key Terminal
    • 1
      Power off the PDT 3100 by pressing the "I/O" button.
    • 2
      Press and hold the "UpArrow," "4" and "Enter" buttons.
    • 3
      Press and release the "I/O" button.
    • 4
      Release the "UpArrow," "4" and "Enter" buttons. The scanner will restart.
    PDT 3100 35 Key Terminal
    • 1
      Power off the PDT 3100 by pressing the "PWR" button.
    • 2
      Press and hold the "UpArrow," "Func" and "Space" buttons.
    • 3
      Press and release the "PWR" button.
    • 4
      Release the "UpArrow," "Func" and "Space" buttons. The scanner will restart.
    PDT 3100 46 Key Terminal
    • 1
    • 2
      Press and hold the "A," "B" and "D" buttons.
    • 3
    • 4
      Release the "A," "B" and "D" buttons. The scanner will restart.
May 04, 2011 | Computers & Internet
I have pro 135 from radio shack. How do I reset it and keep the channels that are programed in it?
The RESET function will clear everything that you have programmed into the scanner and restore original factory settings. You can, however, restore the 150 pre-programmed frequencies after a RESET.
To RESET:
- Power the scanner OFF.
- Hold down the 2, 9, and PSE keys and power the scanner ON.
- CLEAr appears on the display as the scanner resets.
- Do not power the scanner OFF until CLEAr disappears from the display.
To restore the original 150 pre-programmed frequencies:
- Turn the scanner power OFF.
- Hold down the 3 and ENT/PGM keys and power the scanner ON.
Bill B
Apr 28, 2010 | Radio Shack Pro-82 Scanner
PTC-710 telxon Cannot get unit to send new order. Old order stuck in memory. How do you clear all past orders?? Thanks
with the unit off, hold down the two keys on the bottom corner (enter, sp key) and press then release the on key while continuing to hold down the "enter" and "sp" keys until you get a promt on the display.
When a prompt comes up release all the keys. Hold down the 5 key for 3 beeps. The unit will test memory for about 1 min, then beep. Press any key to turn the device off. Then press the on key to power the unit back up.
if you need additional information please let me know.
Kim Ganoe - 800.933.2839 x251
Mar 02, 2010 | Motorola Computers & Internet
160 people viewed this tip
David Payne
David Payne
