Tip & How-To about Sony Playstation 3 (PS3) Console
How to expand the lifespan of your ps3
Here is a few tips to keep your ps3 running a little longer, the first one being make sure it has 5 or more inches either side of it to make sure it can ventilate, second, dont have it standing make sure its laying this helps it ventilate easier, third, hoover it every week, if your warranty is out then open it up and hoover it as long as you know what your doing, fourth, as long as you know what you are doing you could replace the heat sink compound on a ps3 because when sony put it on if you open up your ps3 you will see some care put into it......not, make sure you get a heat sink compound that can withstand at least 140c, because once a ps3 gets to 200c it breaks (happened to mine). thats about all i can think of so use them and good luck.
Sony Playstation 3 (PS3) Console Logo
My Juki MO-655 serger will sew a few inches then the needle thread becomes disengaged in the stitch process. The machine will sew a few inches more then stops making stitches. I have cleaned the thre
Make sure you are threading the machine correctly. Make sure you are using serger thread that isn't old. Make sure you are undoing all the threads when it breaks and thread it from the beginning.
Make sure you have the right needles in their respective places. My Juki MO has two different size needles.
Sep 02, 2012 | Juki MO-655 Mechanical Sewing Machine
what is the capacity for transsmission pan in my chevy cavalier 2.4 1997
If you're just dropping the trans pan of an AUTOMATIC transmission; about 5 quarts. If you mean the entire transmission, its more like 10 quarts. If it's a MANUAL trans, it's a little under 2 quarts.
Hope this solve your question (remember rated this post).
Apr 22, 2010 | 1997 Chevrolet Cavalier
Babylock seger machine keep breaking the left side needle.
Try rethreading the machine, and make sure the thread is not wrapped around anything. Then check the tension for the needles. Run a few inches of chainstich off slowly, while watching the thread and loopers make the loops over the finger. Your threads may be in the wrong position, or underneath the wrong parts to start.
Jun 12, 2009 | Baby Lock Eclipse Serger
I tipped my poulan riding mower up from the right to check belt
If you remove the plug(s) so that the oil all drains back down, and some will drain back out of the muffler, it should start. But give a at least one day, maybe two. You may still have to put new plug(s) in it after it's gone. Check the fuel filter and see if you can see oil in it.
Take off the air cleaner when you get ready to start it and spray just a little starting fluid in the carb, Don't choke it. It will run rough and smoke like crazy, but after it runs a while it should be fine. It make take a few starts before it continues to run. At first it may run just on the starting fluid, but once the plugs fire up enough to burn the oil out it should run on its own.
Be sure and check the oil and if it seems like the slightest amount of gas in it, change the oil and filter.
Let us know how it comes out!
Sirwriter
May 16, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
407 people viewed this tip
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
