Tip & How-To about Plumbing
Remove silicone from your hands
While the best method for evenly spreading a bead of silicone is to use your finger, there's always the problem of getting the silicone off. Soap won't touch it, hand cleaners do a poor job and usually the only method is to let it dry and then peel it off. I figured out a few years ago that all you have to do is grab a plastic bag (one of those thin film bags from grocery stores works great) and rub it on your hands like you would a shop rag. BAM gone. silicon likes plastic even more than your hands. I posted this on a few sites, but when I developed it, I couldn't find any other place online that listed it.
Plumbing Logo
alloy rims lose 10-15 psi every 2-3 weks
you can always put some slime tire sealant in them and hope it elps . Many alloy rims leak check with Hyundai if there is a recall
Apr 21, 2015 | Hyundai Sonata Cars & Trucks
what kind of sealant do i use for leaking gasket
I use a product called Gasket Black. Basically it's silicone. it is available in Black and Grey. when you put it on the gasket make sure there is no oil or other contaminant (like antifreeze for example) and when you use the silicone you want a small bead in a continuous line all around the gasket, DO NOT spread the silicone flat you want a line about the size of a spaghetti noodle.
Dec 19, 2014 | 2000 Kia Sportage
TANK LEAKING CAN IT BE REPAIRED AND WITH WHAT
Find the leak. If it's just the drain plug leaking, see if it has a rubber hose washer in it - could be a simple fix. But if the tank itself has a crack or hole in it, go to any home improvement or hardware store and get clear GE silicone (not latex or silicon/latex caulk). Thoroughly clean and dry the plastic around the leak. Apply the silicone. If you can force a little into the crack or hole itself, do so, then run a thick bead of silicone over the leaking area and spread it out gradually so it feathers out to about 1/2" on all sides of the leak. Clean your fingers or tools with paint thinner. Let it dry a full day before you test it out. Good luck!
Jul 29, 2010 | Agri-Fab Agri - Fab 15 Gal. Sprayer
i am useless at using silicone sealants
Try this: Use the blue masking tape to the limits of where you want the sealer. Place a bead (not too much) along the seam.
Have a bowl of water nearby and wet a finger and smooth the seam keeping your finger wet.
When silicone is set up, remove the tape.
ALSO the little plastic squarish things for trimining the wet caulk work fairly well after you get the hang of it. KEEP removing the waste on them and wet them before each stroke.
Oct 31, 2009 | LG Env Vx9900 Silicone Case
grout in bathroom & shower is cracking, probably due to movement. What is best way to remedy this? Silicone caulking?
If it were me,I would replace the grout,but that's my job.lol
Silicone caulking will just leave an ugly mess if it's cracking in random (large)areas,however,it would keep the water out.
If you have lots of ambition you could try to patch with grout. You would need to purchase the same color of course. Mix up small batches at a time and use your finger tip to spread the new grout into the bad spots or use a small putty knife for spreading it. I wouldn't spend the money on professional tools unless you plan on doing this full time.
Even a piece of cardboard could be used to spread it.
Follow the directions on the grout package,just using smaller amounts. Apply grout,let sit for about 10 minutes,and then wipe up excess with a damp sponge. Make sure you only make one pass at a time and do it gently...rinse sponge between wipes.
Oct 08, 2009 | Home
557 people viewed this tip
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
