Tip & How-To about Computers & Internet
System Restore
Use System Restore to Undo Changes if Problems Occur
Windows XP Professional makes it easier to resolve problems if they occur in your system. You can use System Restore to remove any system changes that were made since the last time you remember your computer working correctly. System Restore does not affect your personal data files (such as Microsoft Word documents, browsing history, drawings, favorites, or e–mail) so you won’t lose changes made to these files. Windows XP creates “restore points” every day, as well as at the time of significant system events (such as when an application or driver is installed). You can also create and name your own restore points at any time. Creating a restore point can be useful any time you anticipate making changes to your computer that are risky or might make your computer unstable. If something goes wrong, you select a restore point and Windows XP undoes any system changes made since that time.
When you run System Restore, a calendar is displayed to help you find restore points. If you don't use your computer every day, some days might not have any restore points. If you use your computer frequently, you might have restore points almost every day, and some days might have several restore points.
To create a Restore Point
1. Access the System Restore Wizard through Help and Support Center. (Click Start, and then click Help and Support. Click Performance and Maintenance, click Using System Restore to undo changes, and then click Run the System Restore Wizard.
2. Click Create a restore point, and then click Next.
3. In the Restore point description box, type a name to identify this restore point. System Restore automatically adds to this name the date and time that this Restore Point is created.
  • To finish creating this restore point, click Create.
  • To cancel restore point creation and return to the Welcome to System Restore screen, click Back.
  • To cancel restore point creation and exit the System Restore Wizard, click Cancel.
To view or to return to this restore point, from the Welcome to System Restore screen of the System Restore Wizard select Restore my computer to an earlier time. Then select the date when the restore point was created from the calendar in the Select a Restore Point screen. All of the restore points that were created on the selected date are listed by name in the list box to the right of the calendar.
To set advanced restore options
1. Open Backup. (Click Start, goto to All Programs, point to Accessories, point to System Tools, and then click Backup.) The Backup Utility Wizard starts by default, unless it is disabled.
2. Click the Advanced Mode button in the Backup Utility Wizard.
3. Click the Restore and Manage Media menu and select the files to restore.
4. Click the Start Restore button.
5. On the Confirm Restore dialog box, click Advanced.
6. Set the advanced restore options you want, and then click OK. See the Notes section for a description of each option.
Computers & Internet Logo
i was trying to uninstall something on my laptop then deleted the wrong thing and i dont know what the name was and know when i try to listen to something the volume doesnt work even if its not on mute
Every time you download or install a new game, application, or software update, you make changes to your computer. Sometimes that change may make your system unstable. Have you ever wanted to go back to the way it was? With System Restore, you can.
System Restore works a lot like the Undo command in Microsoft Word. You can use System Restore to remove any system changes that were made since the last time you remember your computer working correctly. System Restore does not affect your personal data files (such as Microsoft Word documents, browsing history, drawings, favorites, or e–mail) so you won't lose changes made to these files.
Use System Restore to undo changes you’ve made to your computer
Before you open the System Restore console, you may want to save your work and close all programs since System Restore requires you to restart your computer.
There are two ways to access System Restore – through Help and Support or through your All Programs folder.
Through Help and Support:
1. Click Start, and then click Help and Support.
2. Under Pick a Task, click Undo changes to your computer with System Restore.
3. Follow the instructions on the wizard.
Through the All Programs menu:
1. Click Start.
2. Point to All Programs.
3. Point to Accessories.
4. Point to System Tools.
5. Click System Restore.
6. Follow the instructions on the wizard.
Click to go to the
Windows XP System Restore Tutorial
Windows Vista System Restore Tutorial
Aug 26, 2010 | Computers & Internet
Following a System Restore on my Dell Inspiron it has come up with windowsroot system 32 ntoskrnl. The computer was not supplied with the full Window's XP home edition CD, just a Dell reinstallation CD which does nothing at all. I have used the same date on System Restore before without any problems at all. How do I get round this?
If you get that message every time you run system restore, that restore point is no longer any good. You need to try a different restore point on a different date. System restore is NOT meant to be a backup. You need to be running a backup of your computer if you don't want to lose your data. Hopefully you will have another restore point, possibly earlier than the one you used, which is good. If you need to reinstall windows, you will need to get a disk. You can send me a message if you need one.
Jun 13, 2010 | Dell Microsoft Windows XP Home Edition
missing files and photos, settings ect
Log in as Administrator and undo the system restore.
How to undo a system restoration after you perform a System Restore loadTOCNode(2, 'moreinformation'); You may have unintentionally restored Windows XP to a previous configuration that you do not want. To undo the restoration, follow these steps:
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Undo my last restoration, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  4. On the Confirm Restoration Undo page, click Next. System Restore restores the original Windows XP configuration, and then restarts the computer.
  5. Log on to the computer as Administrator. The System Restore Undo Complete page appears.
  6. Click OK. You can now run System Restore again from a different restore point.
Dec 16, 2008 | Dell Inspiron 1501 Notebook
206 people viewed this tip
David Payne
David Payne
