Tip & How-To about Computers & Internet
How to hide user acounts from users
Here is a way to hide User Acounts from users.
goto start/ then run, and type: gpedit.msc
Open the path, user config - admin templates - control panel.
Double click "Hide spcified Control Panel Applets"
put a dot in the "enabled", then click "Show"
click Add button.,
type "nusrmgt.cpl" into the add box.
and walla.
Computers & Internet Logo
windows xp does not display the shutdown screen - I have to shut down via control+alt+delete I want it back?????
To resolve the issue, perform the following:
Click Start, Run.
Type gpedit.msc and click OK.
Navigate to the following path:
User Configuration\Administrative Templates\Start Menu and Taskbar
Double-click "Remove and Prevent Access to the Shut Down command"
Select "Not configured" or "Disabled"
Close Group Policy window.
Oct 30, 2009 | Microsoft Windows XP Professional for PC
My power button has been locked and I dont know how to unblock it?
1. type in gpedit.msc in the Run menu the go to user configurations then Admin Templates, then start menu and then disssable "Remove and prevent access to the shutdown command" log off and log on again
Aug 31, 2009 | Fujitsu Siemens Siemens Basic Line B17-1...
Windows XP Notification tray Bubbles/Notifications No longer show
Right click on the taskbar and look at properties. Uncheck "Hide inactive icons".
If already unchecked, try:
Start-Run type gpedit.msc and select ok.
In User config, open Start menu and Taskbar,
Double-click Turnoff Notification Cleanup in the right panel, select Enable and apply.
Good luck.
Close gpedit.msc and reboot.
Jun 13, 2009 | Microsoft Windows XP Home Edition
prblm with local discs
u drive contain autorun.inf file delete it.
it can be hide
else go to run type gpedit.msc
user config
in that addminstrative template
in that system right side u found Turn off autoplay enable it
for more help call me +919441133420
kishore chowdary
May 23, 2008 | Computers & Internet
111 people viewed this tip
David Payne
David Payne
