Tip & How-To about Computers & Internet
Converting Fat to NTFS
To convert a FAT partition to NTFS, Do these following steps steps.
Click Start, click Programs, and then click Command Prompt.
In Windows XP, click Start, click Run, type cmd and then click OK.
At the command prompt, type CONVERT [driveletter]: /FS:NTFS.
Convert.exe will attempt to convert the partition to NTFS.
NOTE: Although the chance of corruption or data loss during the conversion from FAT to NTFS is Low, it is best to perform a full backup of the data on the drive that it is to be converted prior to executing the convert command. It is also recommended to verify the integrity of the backup before proceeding, as well as to run RDISK and update the emergency repair disk (ERD).
Computers & Internet Logo
i want to format my 2 T hard drive from NTSF to fat 32 , how to do please help
Ok this fix will erase all Partitions on the drive, Make sure you have all data back'd up.
Open Command:
Go to Start menu > All programs > Accessories, right click on Command Prompt and select Run as administrator. Or Type cmd in Start menu search box and hit Ctrl+ Shift+ Enter.
You should have a black MS-DOS prompt on your screen. Type DISKPART in and press enter. Another window will open
Type: list disk It will the display list of devices with memory storage. Find your disk, It should be in a Table(kinda). You have to locate it by its size. so look for 1TB(1000GB) In this Example its Disk 2, yours may differ.
type in: Select disk 2
Execute the rest one by one: CLEAN CREATE PARTITION PRIMARY SELECT PARTITION 1 FORMAT FS=FAT32 ASSIGN EXIT
Wait for one command to complete before running another
You should be left with a working FAT32 Device :P
Regardz Sinn3D
Oct 27, 2010 | Western Digital My Book Essential 1TB...
How can I format my newly bought Seagate 250 GB External Portable Drive into FAT32 system. Are most dvd players now with usb support for divx cannot access external drives that are in NTFS format such as Seagate.
You can specify the format type on the option page for format before you press the format button when displaying the drives in "My Computer"
Additionally, you can CONVERT an existing FAT or FAT32 partition to NTFS. Follow the steps below for Windows XP:
  1. Click Start, point to All Programs, point to Accessories, and then click Command Prompt.
  2. At the command prompt, type the following, where drive letter is the drive that you want to convert: convert drive letter: /fs:ntfs For example, type the following command to convert drive E to NTFS: convert e: /fs:ntfsNote If the operating system is on the drive that you are converting, you will be prompted to schedule the task when you restart the computer because the conversion cannot be completed while the operating system is running. When you are prompted, click YES.
  3. When you receive the following message at the command prompt, type the volume label of the drive that you are converting, and then press ENTER: The type of the file system is FAT.
    Enter the current volume label for drive drive letter
  4. When the conversion to NTFS is complete, you receive the following message at the command prompt:Conversion complete
  5. Quit the command prompt.
Sep 21, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
140 people viewed this tip
David Payne
David Payne
