Tip & How-To about Computers & Internet
HOW TO FIX YOUR DV6000/DV9000/DV2000 All the Problems described are Graphics Related.. Faulty Nvidia Chip..Both Intel And AMD Based Motherboards..Though More Common on the AMD.. The symptoms of the Laptop Powering on and Shutting Off Repeatedly..Or.. Powering On and Having No Video...Or... Power Strip Lights Up, Beeps,Shuts Down...Or..No Power At All...Or.. Intermittant Loss Of Wireless/Video Goes In And Out/Touchpad Slows and Freezes.. To Fix this issue, You will need to Reflow The Graphics Chip. I will Explain In Full Detail As To The Correct Method Below.... HP DV6000/DV2000/DV9000 Compaq v2000 Video Chip Reflow Instructions First Step Is Complete Disassembly Of All Parts And Components.. Remove RAM, Remove CPU, Of Course Remove Heatsink and Fan assembly. Next Step is Insulating the Motherboard... You need to Protect The CPU area, The RAM area, Cover any plastic Plug ports. Try to leave 1/4 inch area around the edge of the chip free of insulation. To Insulate the Board.. I use thick pieces of Tin/Aluminum, you can fold up some aluminum foil (tin foil) About 4 folds thickness.... Now that you have your Motherboard Insulated... Make Sure There's Nothing Flamable Or Burnable Below the Motherboard... it will get quite hot underneath. You will need a Heat Gun.. You can get one of these at your Local Home Improvement Store, they cost about $15 - $30.. You Will Use ONLY the LOW Heat Setting... I REPEAT..... USE ONLY THE LOW HEAT SETTING .... Next You Will Need Some Coins.. Yes Coins.. 8 Quarters and 2 Nickels... Put the 2 Nickels On the Bottom and Stack Quarters On Top... Place The Stack Of 2 Nickels And 8 Quarters On Top Of The Graphics Chip... The Reason for using the Coins: Using the coins serves a few purposes... 1) It Helps Transfers the heat Into The Chip More Evenly/Slowly 2) It Helps Hold The Heat Longer/Then Helps To Cool Slower 3) It Gives The Correct Amount Of Weight That Is Needed To Press The Chip A Thing To Look Out For... Hewlett Packard is nutorious for using the RED epoxy around the edge of the Graphics chip.. this epoxy is used to help secure the chip to the motherboard... This is a process that is Hand Done at the Factory.. And Some Boards Will Have Only A Little Amount of this, Some Will Have Alot of it...And Some are Only Done On The Corner Edges.... If There Is Alot of This On Your Chip, You Might End Up Needing To Carefully (REAL CAREFULLY) Remove as much of this epoxy as able to....You can use a Razor Blade To Lightly Scrape This Off... DO NOT MISS AND SCRATCH THE MOTHERBOARD!!! Go SLOW... Now Comes The Heating Of The Chip... Start With The Heat Gun About 6 Inches Away From The Top Of The Quarter Stack..You want to be holding the gun at a 45% angle.. Aim the heat at the Edge of the chip, You Will Start Rotating Around the Chip- around the outer edge of the chip...then use tighter circles concentrating on the quarter stack, then after about 30-40 seconds, slowly move closer to the chip... Never Move the Heat Gun Closer than the Top Of Your Coin Stack...Then Pull It Back And Slowly Repeat.. The Chip Needs To Get Hot Enough To Re-Melt The Solder Balls On The Underside Of The Graphics Chip Back Down To The Contact Pads On the Motherboard.. and this takes Quite Alot of heating to Do.... You Must Not OVERHEAT the CHip... It Is Best To Underheat it and have to Redo.. than to overheat.. It will cause the solder to break down and even crack/split.. causing failure forever... This process will take about 3 minutes total.. Once you shut off the Heat Gun.. Leave The Stack of Coins On The Chip And Let Sit For Another 5 minutes.. Now Remove The Coins(carefull they might still be hot) Remove All Insulation.. Reinstall RAM, CPU, Heatsink and FAN Assembly (and Of Course Thermal Pads or Paste.. Note:. If Paste Is Used.. It Must Be Silver Paste... Now You Can Connect The Power Button Strip/ Video Cable And The DC Jack Cable.... And Plug In AC adapter .. You're Now Ready To Test For Solid Power and Video.... Upon Sucessful Chip Reflow/Rebake.... You Need To Go To The HP Website..( www.hp.com )..Click on SUPPORT AND DRIVERS, then select...DOWNLOAD DRIVERS AND SOFTWARE....Then either click the box to Auto-Detect System, Or Enter Your Make/Model Info, Once At The Page With All Of Your Drivers.... Choose The BIOS UPDATE Driver.. Choose The Newest Driver And Download/Install It... It Will Reboot The Laptop And Upon Rebooting, Your Fan Will Spin Faster And More Often Due To A Thermal Controller Update In The BIOS Update...
Computers & Internet Logo
Does anyone know where to get the schematic for the dv6550us motherboard?
The closest I come to an HP Pavilion dv6550us, on HP Support, or on the internet is;
Pavilion dv6550tx
Next inline is Pavilion dv6560us,
then Pavilion dv6450us
Not available to the public.
Do have a Block Diagram,
Models that use an AMD processor,
http://www.laptops-schematics.com/wp-content/uploads/2011/07/HP-Pavilion-DV9000-AMD-Notebook-Laptop-Quanta-AT8-Schematic.jpg
1) Socket S1 processor socket,
http://en.wikipedia.org/wiki/Socket_S1
2) Motherboard chipset is an Nvidia MCP51M
Which is the mobile version of Nvidia GeForce Go 6100, or Go 6150;
and Nvidia nForce 430,
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#GeForce_Go_6_.28Go_6xxx.29_Series
Graphics chipset,
http://www.ebay.com/itm/NEW-Original-nVIDIA-Geforce-NF-G6150-N-A2-BGA-ic-chip-north-bridge-Chipset-/271010886762?pt=LH_DefaultDomain_0&hash=item3f1981f46a
Conexant CX20549-12 audio chipset
Realtek RTL8101C Ethernet chipset
Models that use an Intel processor,
http://www.laptops-schematics.com/wp-content/uploads/2011/07/HP-Pavilion-DV6700-Intel-Notebook-Laptop-Quanta-AT3-Schematic.jpg
Uses the Socket P processor socket,
http://en.wikipedia.org/wiki/Socket_P
Both use the Fairchild Semiconductor Industries - FDS6679 - Power MOSFET, and Alpha & Omega Semiconductor LTD - AO4407 - Power MOSFET, in the DC - DC circuit; as far as I know.
Both are Obsolete, but there are cross match examples out there.
(FDS6679AZ for FDS6679, for one)
Indicates HP Pavilion dv9000 series, and AMD; but also matches up to the Pavilion dv6500 series,
http://www.scribd.com/doc/89356925/HP-DV9000
Scroll down. (Zoom In icon { + } at TOP to increase view size,
Zoom Out icon { - } to decrease view size )
Asking for a Schematic, do I assume you are attempting
Board Level Component replacement?
What SMD/SMT IC component are you trying to replace?
(Surface Mount Device/Surface Mount Technology. Integrated Circuit)
Motherboard chipset info, and processor socket info, for processor upgrade.
Same thing for Ram Memory upgrade.
It does use DDR2 Sdram (SO-DIMM), and at 667MegaHertz, to my knowledge.
What usually goes bad on the HP Pavilion dv2000 series, Pavilion dv6000 series, and Pavilion dv9000 series of Notebook PC's?
The cooling for the graphics chipset is inadequate, therefore the graphics chipset overheats, and partially melts the Solder Joints in the BGA surface mount.
Resulting in no graphics.
Power MOSFET's in DC - DC circuit go bad.
Continued in Comment
Apr 07, 2013 | HP Pavilion Computers & Internet
NVIDIA chip not working
I'm interested in buying non-working HP DV2000, DV6000 and DV9000 motherboards.
Go to google and look up precisiondivision . com
I prefer to buy them in bulk, so if you're a shop and have a ton of these, don't toss them - I'll pay you for them!
Nov 06, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
My dv6000 will not come on, the lights come on fro about 2 sec. the shuts down. I replaced the motherboard but still will not power up.
You are in for a rough fix. See the HP forum and follow the directions on this web posting. Get a PC geek to help.
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1269377543004+28353475&threadId=1147659
Search for the date given below:
Nov 22, 2009 16:10:23 GMT Unassigned HOW TO FIX YOUR DV6000/DV9000/DV2000
All the Problems described in the previous posts are Graphics Related..
Mar 23, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
My HP Pavilion dv6500 is running but lcd screen stay black only power light is on I press any bottton but nothing happen,power off then on,stay same... Thanks Milan Detroit
Nov 22, 2009 | Toshiba Satellite P105-S9722 Notebook
When I start the laptop the light comes on but the screen stays blank.
Nov 16, 2009 | HP Pavilion dv9000z Notebook
778 people viewed this tip
David Payne
David Payne
