Tip & How-To about Computers & Internet
How To Increase Computer Speed And Performance
Many computer users are worried about their computer‘s performance. After spending lot of bucks, still they cannot have that charm of using PC as they had expected. Here I am going to explain some major tricks which are used by many computer users which help them to take efficient use of their CPU.
These tips could be of little importance for people who are already using processors with speed more than 2400 MHz but people using computer with less speed and little older mother boards and processors will enjoy these tips. They will realize significant increase in their computer‘s performance.
Here are these tips:
1. Operating system choice:
You will be amazed to know that your choice of choosing right windows or operating system could play a significant role on your CPU’s performance. For example if you are given 5 bricks to carry them to next apartment and then 10 bricks to do same. Think how would be your performance if compared with both situations. Obviously you would perform well when carrying only 5 bricks.
Same is the case with Microsoft windows. The lighter the windows you have, higher the performance will be shown. Now this does not mean that you should install Windows 95. Here is the order of Windows weight: Windows XP (any addition) > Windows 2000 > Windows Me > Windows 98 (the lightest one). So if you have Pentium 4 with good ram then I would recommend you to use Microsoft Windows XP. People using Pentium 3 computers could use windows 2000 or if they have ram more than 256 MB then they can use windows XP too. All other lower speed users should use windows ME or 98.
You would have to compromise between speed and quality. You can decide now which operating system you should use now.
2. Partitions:
Before starting this topic I would like to give you a simple example. Suppose in one case if 100 items are placed in a house having only 2 rooms and you are required to find item no. 89, from second room. You will have to scroll through 50 items in room two to find item 89. In other case if same 100 items are placed in house having 4 rooms and you are required to find item 89 from room 2 then you would have to scroll through only 25 items present in that room and you would spend less time.
Same is the case here for partitions. If you are having more number of partitions, it would help your windows more to find required data easily from your hard disk, when you run any file or program. I would advice you to have more partitions each having at least 5 GB memory and maximum 20 GB.
You should be very careful while partitioning your hard drive and believe me many people make mistakes when they partition hard disk and lose all of their important data. Here is a free resource Windows Setup Guide that can help you to learn about partitioning, formatting hard disks and installing windows.
3. Defragment Your Hard disks:
Your partitions become more fragmented when you create or delete folders, save new files, delete or move them and they become scattered on you hard drive and as time passes, windows become slower and slower due to time needed by the system to find required file on hard disk. You can learn more about why volumes become fragmented by using “Disk Defragmenter” Help.
My main point is that your computer becomes lazy with time. I am sure many of you have observed that after installing windows, computer become slower gradually with time. So I would strongly recommend you that you use Disk Defragmenter regularly, at least a week. I know it is quite boring process but while taking bath, lunch start it. Believe me you will feel the difference later.
4. Frequency of Changing Windows:
I would like you to compare the difference between speeds of your computer when you freshly installed windows and now. I know your answer! Obviously now you will be feeling your PC lazier than before.
This is all due to many factors such as file fragmentation; increasing of windows registry size, increase in number of files and folders in your primary partition and also because of some viruses and spy wares.
I would strongly suggest you that you should reinstall windows after formatting your primary partition at least every 3 months. That will keep your computer always efficient. Many people think that formatting hard drive is not good. That is almost a wrong illusion. Formatting your partition every 3 months and installing fresh copy of windows will considerably increase your computer‘s performance. Same website Windows Setup Guide could help you regarding this matter.
5. My last tip:
Finally do not save junk, programs, movies, games and almost anything you can on your windows partition that is usually C: and believe me your computer would show optimal performance for longer time and provide fewer errors.
It is better you make your “My Documents” folder in other drive than C: as well as make also Program Files folder so install everything like Microsoft office e.t.c there not in windows installation drive. Do it and feel the difference.
Always check for your programs which automatically run at startup and use your computer‘s significant resources. Try to disable them carefully and feel the change in performance. Here is a way to check which programs and processes start automatically when windows starts.
Go to START->Run then type “MSCONFIG” then you can see which your memory consuming programs are.
If you do not want to do anything above and want shorter way with shorter improvements then create new user account and delete previous one. You will observer a slighter change and this also removes many errors if present in windows.
If you cannot even do this then why you wasted your time by reading this article and do something else ;)
I have tried my best to show all possible ways that could help you all to improve your computer performance.
Computers & Internet Logo
Computer infested and very slow
Reformatting is the best solution for that. Just have your important files backed up first in a safe partition like drive D: and then reformat drive C: After successfully reformatting, don't ever open drive D yet because the virus in there might destroy your system and programs again. You can connect to the internet to get the latest version of AVG. If you are willing to spend a few bucks, you can go for paid AV but if not, I am suggesting free AVG as it won't corrupt your system.
Nov 25, 2013 | Computers & Internet
How much will a pet charm that is cute and made from pewter cost me? I really dont want to spend a lot.
Don't worry, you don't have to spend a lot to get your pet a funky charm made from pewter. I found this great website that had something suitable for my 2 dogs and cat: http://www.inkypaw.com/petjewelry.html
Aug 26, 2012 | Anima Pets - Others
avira anti virus can't install
Un-install Avira Anti-virus Then Download and Scan By Using Glary Utilities
Optimize, clean and boost the speed of your Windows.
Protect your privacy and security.
Block spyware, trojans, adware, etc.
Fix certain application errors.
Simple, fast and User friendly interface
For only private use One Click A Day For PC Maintenance, Keeps Any PC Problems Away. With millions of worldwide users, the first-rank & free Glary Utilities is an INDISPENSABLE friend for your PC, with its 100% safe, thorough & quick cleaning and worry-free restoration.
Glary Utilities is a freeware with registry and disk cleaning, privacy protection, performance accelerator and amazing multifunctional tools. It can fix dogged registry errors, wipe off clutters, optimize internet speed, safeguard confidential files and maintain maximum performance.
The era of PC vex is dwindling as Glary Utilities comes. It is a freeware with registry and disk cleaning, privacy protection, performance accelerator and amazing multifunctional tools. It can fix dogged registry errors, wipe off clutters, optimize internet speed, safeguard confidential files and maintain maximum performance.
It is designed for both novice and professionals. User-friendly interface shows clear & detailed directions. For novice, all work can be done with just 1 or 2 clicks, while for professionals, abundant options are available.
To call Glary Utilities helpful would drastically understate the situation. It hopes to become your INDISPENSABLE friend with its one-stop-shop utilities for optimizing and maintaining your PC for best performance. My friend, welcome to have a try for Glary Utilities and have your say! To download Glary Utilities Press here http://download.cnet.com/3001-2239_4-10322935.html?spi=b1d949f58a45ea56498a7664cb708430
Download by Using ATF-Cleaner.exe was once upon a time just my personal temp file cleaner. There became a need for a good temp file cleaner that could do the job safely and without removing files that are crucial to windows, so I decided I'd share it with the public.
ATF-Cleaner has recently picked up alot of interested in the various communities online.
ATF-Cleaners options are fairly straight forward and its simplicity is part of its charm.
The general instructions for its use on the forums are as follows:To Download ATF-Cleaners press here http://www.atribune.org/index.php?option...
then Restart you Computer,after you Computer it is open Windows Now Download Again Avira Anti-Virus Press here http://download.cnet.com/3001-2239_4-10322935.html?spi=b1d949f58a45ea56498a7664cb708430
Jan 03, 2011 | Avira AntiVir Personal - Free Antivirus
bypassing a windows vista password
A lot of people have forgotten their password. So there is no need to be worried. Just see how they solve such problem with Windows Password Recovery 6.0. And you can find it by clicking the blue words
Jan 15, 2010 | Acer Aspire 5100 Notebook
159 people viewed this tip
David Payne
David Payne
