Tip & How-To about American DJ TTD-2500 MKII Turntable
Using a Visual Vinyl Scratcher
Connect The MK II with a Sync Micro 32 visual studio visualiser an see the anolog sound difference..
dj Virusc
American DJ TTD-2500 MKII Turntable Logo
how to connect behringer xenyx 1204usb mixer to a numark mixtrack pro II dj controller?
you have to tell your dj or studio program which device to use as output, but the dj controller doesn't have an audiocard so now i first have to search myself since my mixers have built in serato and another that annoying native i. No i'm just doing difficult while a numarkx5 stands in front of me and the main outputs go to your mixer and your usb is just for recording , but plug the mixer out in the mixer , main out in your monitors and calibrate the sound, but your studie or dj gear wants to know which channel to use and there fore you need to read the manual of your mixer and behringer. It's easy, but not from here.
Jul 27, 2014 | Behringer Xenyx 1204USB
how do i connect my soundbar to my technika lcd 32-244 tv
There should be a output on the TV. Hook the sound bar up, set the TV up to use external sound and use the sound bar remote untill you sync it to a different remote. Give it a try!!!!
May 22, 2014 | Televison & Video
Sunfire MK II Subwoofer hum. I have a Sunfire MK II subwoofer that hums when it is plugged in (it even hums when no signal is connected). I've tried multiple outlets on different circuits, but hum continues. Shouldn't the internal power supply should filter out this hum.
you have a ground loop issue you could purchase a ground loop isolator, jensen makes them for about 40 bucks.I have discovered that if you have cable tv, unplug the incoming cable in your cable box and see if hum disappears.
Nov 25, 2010 | Sunfire True Sub MK II Subwoofer
After I sync music to the player from windows media player, it says there are no songs on the device. Do I need a memory card?
I would think so...because ii have the micro sd nd its not syncin the music on to the micro sd memory card
Dec 26, 2009 | Visual Land V-Touch Digital Media Player
812 people viewed this tip
Top American DJ Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an American DJ Audio Player and Recorder Expert? Answer questions, earn points and help others
