Tip & How-To about Nokia 6600
How to full format your Symbian S60 phone Full phone formatting on a 6600! If you encounter situation like below on your 6600, 1. Blank screen phone unable to reboot. 2. Phone only able to boot-up to "Nokia" word screen. 3. Install some program but not able to uninstall it after that. 4. Error messages such as "Child Installer" keeps popping-up. Do a Full phone formatting on your 6600! as steps below, 1. Make sure you have at least 3/4 charge of battery power left. 2. Backup your contacts list and personal files to MMC memory card. 3. Switch-off your 6600 phone. 4. Press and hold 3 keys; Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the 6600 phone. Remember, do not let go all of the keys and hold keys until you see a formatting word screen show! 5. After a few minutes when the Full phone formatting completed, your 6600 will back to original system and factory settting. All apps installed & not of the phones' default will be lost. If you did a backup on your mmc, you can restore it back to the C drive again.
Nokia 6600 Logo
how to format nokia 6101
First thing first, not all the Symbian phones can be formatted by the so called "Formatting codes" (Will not work in Series40 phones like Nokia 6300, 7210, 5130 etc and the older Nokia Generic OS based phones like Nokia 1600, 2600 etc). These phones can only be formatted through flashing (Re-installing) their OS software (Firmware) via data cable and computer. Only Symbian S60 (And a few of other series) based mobiles have built-in support for the format codes. So format codes will work in all Symbian^1 (S60 1st, 2nd, 3rd, 5th edition) phones like Nokia 3650, 3660, 6600, 6630, 6680, 6681, 3230, 7610, 6670, 3250, N70, N72, N73, N75, N76, N77, N78, N79, N80, N81, N82, N83, N85, N86, N90, N91, N92, N93, N95, N96, N97, 5800 and other touchscreen phones plus the newer Symbian^3 phones (Nokia N8, C7 and E7 etc). Now lets begin with formatting process: There are two methods to format the phone depending upon the situation: A. When the phone is in working condition:
Just press any of the following two codes at standby screen *#7780# or
*#7370#
Phone will ask for confirmation and security code (Default security code is 12345), enter it and bingo everything in phone memory will be erased and phone will be back to factory settings.
B.
Hard Reset - When the phone is not starting-up (i.e. not working after white screen or Nokia Logo screen)
- then follow these steps: 1. Switch-off the phone
2. Press and hold following three keys simultaneously (Remember "All the three keys" simultaneously):
Green Key (OK or Number Dialing key), Star key (*) and Three key (3 number key)
3. While still holding the above three keys, press the power on/off key to switch-on the phone.
Still continue holding the three keys until the "formatting" screen appears. Now you can release the keys, confirm if asked and then wait for the format to complete. Now the phone will be restored to its original factory settings. Read HERE to know about hard resetting Nokia N97, 5800, 5230, 5530 and other touchscreen S60 5th edition phones.The above format will reset the phone but most probably will not clear the operator's lock codes.
Follow the instructions below to format Nokia 9300/9500 (Communicators)
1. Restart the phone
2. Just when the "NOKIA" logo appears on screen, PRESS AND HOLD following three keys simultaneously:
Shift (Up Arrow key) + Ctrl + F
3. KEEP HOLDING them until phone prompts you whether or not to proceed with format. If however the format menu does not appear this way then remove and re-insert the battery and try again. If the phone display remains black after inserting the battery, press power button on the phone side while keeping the cover open and repeat the above procedure. After formatting, phone will reboot. If the screen remains white after reboot, press power button on the phone side while keeping the cover open.
NOTE: Before formatting the phone, make sure -
1. That you backup all your phone data to either computer or memory card as formatting will erase everything in phone memory.
2. That the phone's battery is charged fully or is plugged in AC power because if unfortunately, the phone runs out of battery during format, then the phone may get permanently damaged and irreparable.
3. If your phone is infected with a virus (Only applies to 1st and 2nd edition phones) then also format the memory card and scan it with a good computer antivirus like Avast.
I hope that the above instructions will help the needy.
Oct 06, 2011 | Nokia 6101 Cellular Phone
nokia 6600 mp3 problem
Jul 20, 2009 | Nokia 6600
suggested solution
If you encounter situation like below on your 7610,
5.Start up phone failed contact re-tailer
Do a Full phone formatting on your 7610! as steps below,
3. Switch-off your 7610 phone.
5. After a few minutes when the Full phone formatting completed, your 7610 will back to original system and factory settting.
Thank you for rating this Tip.
Mar 13, 2008 | Nokia 7610
start up failed contact the retailed
If you encounter situation like below on your 6630,
5. Contact Re-tailer
Do a Full phone formatting on your 6630! as steps below,
3. Switch-off your 6630 phone.
Remember, do not let go all of the keys and hold keys until you see a nokia logo goes to white or it will blink....
5. After a few minutes when the Full phone formatting completed, your 6630 will back to original system and factory settting.
Feb 20, 2008 | Nokia 6630 Cellular Phone
1,753 people viewed this tip
Top Nokia Cell Phones Experts
270rexton
270rexton
