By
Fixe_You
Rank: Wiz
Rating: 82%, 1014 votes
posted on Nov 09, 2009
Hello.
Welcome to
Fixya Community.
- Verify if the computer meets the minimum system requirements
of the product. This is to ensure that the software and the player
itself are compatible with the computer’s operating system
- Ensure that there is enough battery charge and switch it on before connecting to a computer
- Ensure that Windows XP has Service Pack 1 or Service Pack 2 installed with all other security updates from Microsoft
To verify your service pack version:
Click Start button > Run > type winver
- If the service pack is not installed, please proceed to download them from microsoft at:
http://www.microsoft.com/windowsxp/sp2/default.mspx
For Windows Vista, kindly update to Service Pack 1 at least.
- If
the player is still attached to the USB port, disconnect it from the
computer. Gently push the end of a thin object (such as a pin or
straightened paperclip) into the Reset hole.
The reset button for your player is located at the bottom of the player, to the left of the sync adapter port.
If the above procedures still do not resolve the detection issue,
kindly refer to other alternative steps below to continue solving the
issue.
- Check all connections to make sure that the player is
properly connected to the computer. Try connecting to a different USB
port preferably the one located at the back of the computer
- Access the Recovery Mode of the player and perform a clean up and reboot
- If the issue persists, please Launch Control Panel and double click on System option.
Under the Hardware tab, please click on Device Manager button
- Under Device Manager, right click your player under "Disk Drives" and
select Properties. If the player is working properly,
you will be able to see the following message "This device is working
properly”
- If you are having issues with this device, click Troubleshoot to start the "troubleshooter".
- Please verify if there is any exclamation mark on Portable Device.
Right click My Computer icon from Desktop area > Properties > Hardware Tab > Device Manager
Double click on Portable Devices and verify if there’s a yellow
exclamation mark. If there is, right-click on the player's name and
choose Update Driver.
- Should the issue persists, try connecting the player to a different computer to isolate the situation.
Thank you For Using Fixya.
I hope this Help you.
Can you Help with these MP3 and Digital Media Players problems?
SanDisk Sansa e250 MP3 Player
first, my dell laptop won't recognize my sansa e250 and i...
i can't seem to delete songs off of my Mp3 on Windows...
I have been transferring audio from my pc to the sansa 250...
i cant put itune song on it
keeps getting needs to sync to use music but some of the...
