Tip & How-To about Panasonic Workio DP-4530 Copier
Panasonis Workio DP-4530 service manual?
Hello
My name is Edo and I am IT for UN mission in Afghanistan. We have copier Panasonic Workio DP-4530 and it is heart of our design office. We use copier for publishing documentation, for copying and printing. We can find any normal service in Afghanistan. The nearest place for repairing is Dubai.
I have experience with copiers and I want try to fix our copier. Currently, our new problem is error “clean fusser web”.
I need only if anybody have service manual in pdf or similar format. I will be very appreciated if anybody can help us. Your any advice is welcome as well.
Mr. Edin Husejnefendic
IT Systems Manager
Vertical Structures Unit
Afghanistan Operations Center (AGOC)
United Nations Office for Project Services (UNOPS)
House No. 6, Behind Emergency Hospital
District 10, Shar-e-Naw
Kabul, Afghanistan
Mobile: +93 0799 303-021
http://www.unops.org
Panasonic Workio DP-4530 Copier Logo
Printing envelopes from bypass tray
Yes insert and selct the thick stock
Dec 01, 2008 | Panasonic Workio DP-4530 Copier
mirror image
sorry, no you can not
Nov 25, 2008 | Panasonic Workio DP-4530 Copier
Panasonic 4530 copy machine
enter to program f9 coo then yes u can reset all parameter of ur machine
Nov 10, 2008 | Panasonic Workio DP-4530 Copier
for copier panasonic workio dp-4530
you mean all departments codes?
if you are the person incharge of copier on your company,
1) press function, gen settings, depart. mode,
2) input the 4 digit key operator code, the search for department mode again.
3) press the department code on the left side of the touch panel then you can erase each department code.
i hope hope this is helpful
Jul 17, 2008 | Panasonic Workio DP-4530 Copier
Req: Panasonic Workio DP-4530 service manual
In the service mode there might be an automatic fuser and drum cleaning mechanism that could be activated. The fuser web is in the drum section of the unit and when this is coated with toner and the cleaning mechanism is inactive, you could get this problem.
Let me know if you do not know how to get into the service mode of the copier. It normally is pressing the following three buttons simultaneously - Original, Function and the number 3. It may take a few tries before you get the sequence properly. Also, if it requests a password, try 0000 or 00000000 (8 zeros or 4 zeros)
Jan 06, 2008 | Panasonic Workio DP-4530 Copier
2,204 people viewed this tip
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
