Tip & How-To about LG Prada KE850 Cellular Phone
Concise tech info-MEDIA
Photos  -   JPG sized 640 x 480 only.  Other sizes will not function on the phone. Sounds -   MP3 only - do not download any other audio file type to the phone. Video    -   3GP only - you cannot download any other video file type to the phone.
If you need ripper information for OS X let me know.
LG owes me one!
El
LG Prada KE850 Cellular Phone Logo
I can no longer upload my photos. What is going on?
JigZone Photo Upload accepts pictures of JPG and GIF formats only. All puzzle pictures are a fixed dimension, 400 pixels wide by 300 pixels high:All puzzle pictures are stored with a maximum file size of 20KB (20,480 bytes). Photos which have a file size greater than 20KB will be automatically compressed, which could result in a loss of picture quality. For fast uploading and maximum picture quality, we recommend that your edit your pictures to be 400 pixels wide by 300 pixels high and have a file size no greater than 20KB before uploading them.Note: GIF type images cannot be automatically re-sized and must be formatted to 400 x 300 and less than 20KB before being uploaded.To limit the bandwidth costs of this free service, at this time the file size of a photo upload is limited to 2M or 2,097,152 bytes. Large sized photos could take several minutes to upload. During this time the upload page will remain on the screen.
Mar 26, 2015 | jigzone.com
I am not able to play MP4 files in Nokia e63. I have real player installed...
Hello First of all i have to tell you that not all type n all size MP4 file is not played into mobile real player for particularly your E63 you have to check for 320x240 or maximum 640x320 size with mpeg or h263/264 video codac n aac or mp3 audio codec for checking this that what type of MP4 files suppots on your phone check specification of your phone on fonearena.com.
& for converting different files to specified your mobile file use any video converter like xyllisoft or total video converter.
If still there is problem then you have to go to any NOKIA costumer care for updating your mobile software. Sometime because of viruses software may corrupt and some functions may not work so check for it.
Hope this will solve your problem. ALL THE BEST...
Jul 07, 2010 | Nokia E63 Cell Phone
file format not supported...what does that mean
Not supported format concerns one or more of the next items:
  • size: the memory size of the file ( too small or too large)
  • layout: the size of a frame for video or photo, bitrate or identification tags for music,
  • extension: the suffix added after the dot file name
e.g. photo1.jpg or photo2.tif
  • digital rights management: copy protected files sometimes can
be played, but cannot be transferred mostly.
Media like photos and videos
1. Need to have the supported format as required for the software called "Media Converter" on the computer.
2. A Media Converter must be used to convert the format into a model that can be read on the player before it is accepted to do a transfer.
Music
1. Must have the supported format as required for the player.
The identification called ID-tag contains the name of the song, artist, album etc.
The bitrate of music says something about the quality / sample rate
of the song: when converting cd audio to e.g. song1.wav or song2.mp3
(called "ripping") the quality depends on the presettings of the audio
conversion.
Sep 14, 2009 | Philips Audio Players & Recorders
LG Prada receiving via bluetooth troubleshoot
There is a restriction in the JPG ratio/pixel size on the Prada.
You need to first get your photos on to your computer and check the size of them is 640 x 480 and that they are standard .jpg
Make sure any file you send is not 'in use' I.E. you don't have the file open on your computer - open files/in use files cannot be sent.
Also, after every download to the phone, you need to move the jpeg file to the external memory as the phone itself can only cope with a few files at a time before registering as full.
Dec 30, 2007 | LG Prada KE850 Cellular Phone
Confused about Resolution Sony DSC-T7
2.2 MB is the size of the file on your hard disk. Being a .jpg, it is a compressed file. The file size does not reflect the size of the image stored inside the .jpg. Yes, the size sounds about right. It will increase or decrease depending on how much detail there is in the picture. If, for instance, your picture is made up of nothing but uninterrupted blue sky, the disk file will be quite small - as the .jpg does not need to store much information (the more repetitive information, the smaller the file). On the other hand, if your photo consists entirely of nothing but blades of grass, the disk file will be comparatively large. When you see "DPI", that refers to print resolution. So, since you're not printing, but rather, viewing onscreen, Photoshop "assumes" a convenient "screen resolution", as though you printed on the screen (don't ask!). If you look at the other settings, you'll note that Photoshop also thinks your photo is 36" wide!!! You adjust the DPI (or photoshop will) when you print. Till then, it doesn't mean much. Let me give you an idea of your image's possible DPIs. Assume you really want to print a 36" photo: 2592/36" = 72 DPI If you make the picture 12" wide: 2592/12" = 216DPI At 10": 2592/10" = 259.2 DPI At 8" 2592/8" = 324 DPI How do you get my photos above 200 DPI? By printing the picture small enough, less than 12.96" on the wider side. See calculations above. The resolution at which you shot the image (2592X1944), will not cause blurriness. As for the cause? There could be any number. Was the subject moving? Were you? Did you shake the camera while shooting? Is your shutter speed too slow? Should you have been using flash? Is the camera autofocusing correctly? Are you waiting for the autofocus to lock before pushing the shutter the rest of the way? Etc. Hope this helps somewhat...
Sep 12, 2005 | Sony DSC-T7 Digital Camera
1,777 people viewed this tip
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
