Tip & How-To about LG Prada KE850 Cellular Phone
Audio files/MP3 and ring tones
Discovery: You are able to download wave files (and other audio file types) to your phone and even be given the feature, 'set as ring tone' -DONT.
You will find that your phone malfunctions if you set anything other than an MP3 from your phone's MP3 folder, as a ring tone.
It's the fault of the phone's firmware that leads you to believe you can select a ring tone from an audio file that is stored outside of the MP3 folder.
 It is also evident, with the limited memory the phone itself has to store MP3s, that you will NOT be able to personalize ring tones for every contact in your phone book!  Again, this is not explained in the manual properly and has led to much confusion surrounding MP3 functionality on the Prada LG.
I hope this helps.
LG Prada KE850 Cellular Phone Logo
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
How do u turm the music in the player to a ringtone
before you can turn your music to the ring tone, you have to turn your music files into wave files and than you can get the wave file to work as a ring tone.
Nov 15, 2008 | LG RUMOR Cellular Phone
Set Ringtone
I have had a few Nokias and they all are different. I dont want to steer you in the worng direction. Check out the user guide located here; http://nds2.nokia.com/files/support/nam/phones/guides/7610_US_en.PDF Best of Luck.
Sep 13, 2007 | Nokia 7610
2,033 people viewed this tip
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
