Tip & How-To about Sony KP-46WT510 46" Rear Projection HDTV
Convergence Fix
Found this on another page here on Fixya. Thought I would post it again since it helped me fix my TV.
Here are some of the most common symptoms and examples of a convergence problem.
This is a very common failure on Projection sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Note: If you set has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing or you can call in a pro.
If you want to do the repair yourself check the site www.TvRepairKits.com.
Their kits include a step by step instruction guide, original OEM STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant,step by step instructions, etc.
Sony KP-46WT510 46" Rear Projection HDTV Logo
how do I find my post
Hi Dawn,
Even though you found your post, I thought I'd provide a solution to help others who might have the same problem.
There are 3 main ways to find your posts:
  1. My Account:
    You can find your post by clicking on your avatar when signed in and then clicking the "My Account" link that shows in the dropdown. Once on the my account page scroll down to the "My Problems" or "My Solutions" sections to see all the problems or solutions you have posted.
  2. Homepage Activity
    When you post a problem or solution a notice is displayed on the homepage (when signed in) for each problem, solution, or comment you have posted.
  3. My Profile:
    You can also view your profile to see the latest activity you've have posted. Just click on the your avatar at the top right when signed in and click the "My Profile" link that appears in the dropdown.
I am glad you found your post, but hopefully this will help others who may be having the same issue.
Hope that helps!
Apr 08, 2014 | FixYa Computers & Internet
I do not have the manual, so pages 6 thru 12 I do not have.
Did I not post the link? I thought I posted a link to an online manual for you. I apologize. If you would be so kind as to remind me of the manufacturer and the model number of your tv, I will post that link right away. Again, I apologize for the mistake Sincerely, Der Strom
Apr 14, 2010 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
cannot program tv lost manual
http://www.fixya.com/support/p139201-quasar_sp_3235_32_tv/manual-18430/page-7. Copy this link and paste it in the address bar of your browser and it will take you to the auto programming page set-up. You can look at the complete owners manual and find all the instructions for the operation of your television. I hope this information helps you with your problem.
Apr 03, 2009 | Quasar SP-3235 32" TV
Remote no longer works
the manual for this remote can be found on this site
http://www.fixya.com/support/p237065-ge_rm24930_remote_control/manual-11900/page-2
unfortunately i do not have a code list for this remote, but you should be able to use the code search function to get everything working again.
hope this helps,
trin
Nov 17, 2007 | GE RM24930 Remote Control
2,282 people viewed this tip
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
