Tip & How-To about Blaupunkt CD52 CD Changer
S*t happens
I`ve got Blaupunkt Heidelberg CD52.Every time when I wanted to listen the radio,he have been writing: Tell Navi.What is that mean?Because the radio is not working after that message
Blaupunkt CD52 CD Changer Logo
what button do I press after inserting blaupunkt radio code on my Valencia CD52 model? I pressed the ok button last time and I got the message code locked.
Are you sure you require a code as my database says that this BP VALENCIA CD52 is a NON CODED model.
If not , then find your Blaupunkt Radio code entry instructions here
http://www.radio-code.co.uk/code-entry-help-Blaupunkt.htm
Nov 07, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
My Blaupunkt, Heidelberg CD51 car stereo beeps every minute or so, whether you're listening to the radio or CD's? - HELP please
That normally means that it requires the  security code to be entered.
Disconnect the fuse for 10 minutes, replace then enter the code.
If you do not have the code then the radio will have to be removed from the dashboard and quote all the letters+numbers on any labels, barcodes or stamped in the metal casing.
Also quote the make of car it is fitted into.
Aug 31, 2009 | Blaupunkt Heidelberg CD51 CD Player
blaupunkt casablanca cd52 radio/cd
Youi'll probably need an adapter cable which you can get from audio store, or an auto parts store
May 11, 2008 | Blaupunkt CD52 CD Changer
1,189 people viewed this tip
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
