FixYa.com
Greasy marks on cloths; All washing machines
naynay69a
By Wiz naynay69a
Rank: Wiz
Rating: 82%, 46 votes
posted on Jan 03, 2008
Not Rated (0)
90% of greasy marks on cloths is due to scum build in the outer bowl of your machine...top loaders being the most vulnerable. prevention is better than cure. At least one hot wash a week on high level. If your machine is an early model one or two with a good bleach subject to manufacturers instruction...bleach is very cost effective and works well.
Did you find this Tip Helpful?
Comment #1
posted on Apr 10, 2008
MDX2008HOU
By Apprentice MDX2008HOU
Rank: Apprentice
Rating: 0%, 0 votes
If you are experiencing greasy marks on your cloths, let me ask a question. Are you using a fabric softener? If you are, use Downy only. Other fabric softeners are made with wax, the wax builds up on the inside of the drum, thus depositing on your clothes during wash and rinse cycles. My LG frontloader has a tub clean cycle that uses hot water and bleach.
Comment #2
posted on Apr 09, 2008
woodyjab
By Apprentice woodyjab
Rank: Apprentice
Rating: 0%, 0 votes
greasy marks on clothes in top loading washing machines can also be caused by leaking seals from the gearbox, i have found this problem on many machines i have reconditioned....it is best to get this checked out first as it can be costly to remove oil,grease from the clothes and dissapointing if theyre ruined.
Can you Help with these Washing Machines problems?
Bosch WFMC 3200 Front Load Washer
exxcel 7 washing machine
how do I turn off the end of... Answer This...
Display does not light up.
Washer seems to work fine...... Answer This...
bosch fabric softener does...
Bosch front load WFMK6400UC... Answer This...
Bosch WFCM 3200 Front load...
I have a 2004 model I bought in... Answer This...
the water heater was cycling
the water heater was cycling on... Answer This...
Sponsored Links
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
