Tip & How-To about Frigidaire GLTF2940ES Front Load Washer
1st thing to do with eletronic error codes
This is valid for most electronic devices..In my field...major home appliances.
Always consult your owners manual first. In the back should be a listing of basic error codes ie you can deal with them...eg. pump blockage..checking tap filters..cleaning and checking vents. This saves lots of $$$$$. With late model Appliances 70% of faults are due to these factors and are not covered by manufactures warranty in most cases.
Frigidaire GLTF2940ES Front Load Washer Logo
When our power went out for about 20 mins & came back on our Maytag stove started beeping and the touchpad display is all gibberish..words, numbers letters etc and none of the buttons willwork. The burners turn on but the touch d seems stuck how do we fix?
I suggest you study the instruction manual and maybe contact the manufacturer in case there is a reset method.
It shouldn't be overlooked that a power outage is often accompanied by a power surge or a voltage transient or spike capable of damaging sensitive electronics, in other words computers!
Almost everything is a computer these days, which is why every home should have major appliances provided with surge protection and some area protection. Half a dozen surge protectors around the home protecting major appliances will provide a degree of "herd" protection to some of those items without direct protection.
Mar 04, 2018 | Maytag Stove / Oven / Range Cooktop -...
how to disassemble
Owner's Manual and Installation Instructions: Search Tips
  • Be sure to use the model number of your appliance to locate use and care manuals.
  • Model numbers are normally printed on tags located inside or on the back of your appliance. Find the model number on your appliance.
  • check to make sure you entered your model number correctly, or call 1-800-626-2005.
  • This search is for manuals for major appliances only. Manuals for small appliances and electronics are not included. Need to find manuals for other GE products?
Jan 10, 2013 | GE Dryers
want owners manual for kenmore dryerelite heavy duty king size capacity ultra quite pake
Sometimes all you need to get your major home appliance working is the use and care, owner's manual or user's guide that has long since disappeared. The resources listed here will help you to get a replacement manual with the minimum of fuss.
Some of the larger manufacturers now make owner's manuals, care and use guides and installation instructions available for download on-line in Adobe Acrobat .PDF file format. If you don't already have the Adobe Acrobat plug-in for your browser or an Adobe Acrobat file reader, you can get it for free here:Of course the exact model number off the appliance (and occasionally the serial number as well) will be required to get the proper manual for it.
If you need help in locating the model and serial number identification tag on your dishwasher, fridge, stove, clothes washer, dryer or other *major* home appliance, check the Appliance411 'Repair Parts' section's
Dec 21, 2010 | Dryers
how to wire a vulcan for 240 installation
find power box. see if you have 2 spare breakers avail. next determine power requirement for appliance example 20 amp./ 30 amp breaker a 30 amp load will require a larger wire size example # 10 wire always consult owners man. or manf.instructions reg. if 208/240 is ok should say in owners manual always follow local/ nat electrical codes.
Jan 14, 2010 | Kitchen Appliances - Others
all TV's in house failing, a few at a time
Hey PNorris,
If multiple electronic devices are failing in your home all at once, I would probably first have to ask if your home recently experienced an electrical storm or major power surge of any kind.
Normally the effects of such large-scale surges are immediately noticeable - TV's and other major electronic devices may fail to turn on, fuses may be blown or circuit breakers tripped, and in some cases electrical wiring may be melted.
If nothing like this has happened recently, low-level power surges may still be a potential cause of this problem. When the motor from any large appliance (such as an air conditioner or refrigerator) turns on or off, it often diverts power to and from other electronic devices using the same circuits. This fluctuation in electrical current may result in low-level power surges to every connected device. While not immediately noticeable, these low-level surges can often cause the eventual failure of (and gradually degrading quality in) many audio/video components.
Typically, the easiest way to avoid situations like this is to make sure that outlets are not overloaded and surge protectors are used with every major electrical device in your home. For older homes however, replacing the house's wiring may be necessary. Homes that were originally built at the turn of the 20th century may not always have wiring capable of supporting the electrical needs of many modern appliances.
Ultimately, this means that in addition to contacting your local TV repair facility, you may want to also speak with an electrician. This is probably the best way to determine whether or not power surges have caused these failures, and may give you a better idea how to proceed.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 12, 2008 | Televison & Video
2,064 people viewed this tip
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
