Tip & How-To about LG Prada KE850 Cellular Phone
Correct jpeg sizing
Here is the MAGIC NUMBER that you should ensure your jpegs are sized, to properly enter to your phone book for personalizing contacts.
Make sure all your jpegs are saved sized: -
640 x 480
The phone doesn't seem to adapt any other image size when assigning to the caller contacts list, so be careful, all you graphic designers who use photo shop/in design/iphoto etc!
LG Prada KE850 Cellular Phone Logo
how do I set up speed dialing on my HP Officejet 5740
While "Speed Dialing" or "Speed Dial" is listed in its fax specifications on some sites, it appears to be a mislabeled categorization of its group fax feature as HP's manual makes no other mention of it--save to say, the "fax to multiple numbers" (or multiple recipients) feature. There does not appear to be a speed dial list, but there is a phone book feature for adding contacts (individual numbers) & groups. (The following is detailed in a more explanatory way on pages 65-66 of the user's manual (http://support.hp.com/us-en/product/HP-Officejet-5740-e-All-in-One-Printer-series/6617253/model/6617254/manuals?cc=us&lang=en).
1. From the printer control display, touch Fax.
2. Touch Send Now.
3. Touch the telephone symbol to access its phone book feature.
4. Touch the person symbol for a phone book contact; or touch the multiple person symbol for a group of phone book contacts.
(Note: Contacts should be established before any of these could be added to any group.)
5. Touch + (plus sign) to add a contact/group; or touch the gear symbol (edit) to edit/delete a contact/group.
6. Touch Name.
7. Changes to contacts/groups:
•Adding a contact/group: type the name, & then touch Done.
••Adding a fax number to a contact: Touch Fax Number, enter this contact's fax number, & touch "Create".
••Adding a contact to a group: Touch Number of Members, select all of the contacts to add to this group from this printer's phone book, & touch Select followed by touching "Create".
•Editing: Select the contact/group name, & then touch Done. Then...
••Editing a Contact: touch Fax Number, enter the fax number, & touch Done.
••Editing a Group: touch Number of Members & deselect the contacts to remove from this group or touch + (plus sign) to add contacts to this group. Then touch Done.
•Deleting a contact/group: Select the name, & then touch Delete followed by touching Yes.
Feb 25, 2015 | HP Office Equipment & Supplies
M USING 1600 NOKIA MOBILE PHONE BUT SOME TIMES I CANT SEND MESSAGE.
Welcome to FixYa
  1. Check you Properly inserted SIM[Working SIM]
  2. Ensure you are in Sufficient Range/Phone in Network Signal
  3. Check you have Enough Balance to Send Message
  4. Some times Network/Message Server MAY DOWN[Contact your Provider]
  5. Properly Configure Message Settings
Go to
  • Menu
  • Messages
  • Message Settings
  • Sending Profile
  • Message centre Number
  • Enter Proper Number[Proper Number will Get by Contacting Customer Care Center/From Your Network Provider-It means this number Different in Different Providers]
Here is also Guide for Your Product Click..
Now your Problem Solved....You can feel free contact me...If this Helped -Rate ME..Thanks for Contacting FixYa...
Jun 29, 2010 | Nokia 1600 Cellular Phone
Entering dual or triple phone numbers in phone book
Go to the entry details of the person you are setting up,
Chose the more option and then select the phone number option. It now will let you enter another number. Once you have finished and selected done it adds the name and an alternate number in your phonebook.
I hope this helps.
Regards
Alan Hood
ami-man
UK
Mar 03, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Pictures transfered on the phone doesnt show!!
Here is the MAGIC NUMBER. Make sure all your jpegs are saved sized: -
640 x 480
The phone CANNOT ADAPT any other image size it seems.
Jan 01, 2008 | LG Prada KE850 Cellular Phone
Unable to assign photos
640 x 480
The phone CANNOT ADAPT any other image size to the caller contacts list!
Oct 26, 2007 | LG Prada KE850 Cellular Phone
1,859 people viewed this tip
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
