Home | All Products | HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook | Tips
Laptop is turning off by itself.
ginko
By Guru ginko
Rank: Guru
Rating: 89%, 5020 votes
posted on Oct 25, 2009
Helpful
Hi.
If computer turns off when idle, then check power saving settings, accessible from control panel.
If laptop turns off while you are using it, try first reinstalling the system to exclude system problems, or test the laptop starting OS from CD or staying in Bios settings mode, so to exclude installed system.
If laptop is still shutting down, then problem may be overheating.
Overheating usually happens when the fan is not coming , therefore when the computer overheats.Or the fan is not cooling enough and computer is overheating.
Monitor computer temperature using a software, check if Fan is coming up when temperature gets critical.
If fan comes up but does not cool enough, then replace the fan, it is not efficient anymore because of a bad bearing or dust. ~Also ensure that fan is well mounted, if fan has poor contact with CPU surface , cooling will be poor.
If fan does not come up, and critical temp is not detected, then the sensor on motherboard is bad, this is very uncommon. When this happens the problem is usually related to system or power settiings , rather than overheating.
If fan does not come up and temp is critical, then fan is faulty, replace it.
There are also more than one fan on many laptops, check that one of the fans (CPU fan, video fan) is not completely ded, and therefore cause for the problem.
By using the software below you can also find out if the problem is really overheating. If temperature results within normal range, then usually it is not overheating.In that case test systtem and check power saving settings.
Here is the software to control your fan and temp. sensor state:
Download SpeedFan - Access temperature sensor in your computer
Download SpeedFan 4.38
SpeedFan - Free software download
Comment by ginko, posted on Nov 14, 2009
Hi.
If the laptop is turning off when idle, then check power saving settings, accessible from control panel.
If laptop turns off while you are using it, try first reinstalling the system to exclude system problems, or test the laptop starting OS from cd or staying in Bios settings mode, so to exclude installed system.
Monitor computer temperature using a software check if Fan is coming up when temperature gets critical.
If fan does not come up, and critical temp is not detected, then the sensor on the main board is bad, this is very uncommon. When this happens the problem is usually related to system or power settings , rather than overheating.
By using the software below you can also find out if the problem is really overheating. If temperature results within normal range, then usually it is not overheating.In that case test system and check power saving settings.
Was this helpful?
Yes
No
1 person thought this was helpful
Can you Help with these PC Laptops problems?
HP HP Pavilion dv2000t 14.1" Notebook...
Got a HP DV2000 when I boot everything looks normal, then...
sometimes does not power on. no sounds no image. but...
my screen keeps flickering with mobile pc presentation...
i cant open my yahoo messenger webcam
HP dv2000-built in webcam displays black,lights on.---i...
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
