For chuck removal first remove the chuck retaining screw which is LH thread. If this tool has a high/low selector shift to LOW and if equipped with a clutch shift to the drill only position. Find a bent handle allen wrench about the size of chuck capacity (the larger the better, less flexing) and insert the short portion into the jaws and tighten. Position the chuck on a workbench or block of wood with the longer portion at about a 30 degree angle so you can strike it counter clockwise with a hammer, strike the longer portion and the chuck should loosen (it is standard thread pattern) It might take a couple hits to remove. Chuck installation would be to reverse the above to seat the chuck and reinstall the screw.
I have a cordless dril...3/8'' 9.6v and i don't have the manual...not sure how to get the pices to...
(More)
I have a cordless dril...3/8'' 9.6v and i don't have the manual...not sure how to get the pices to stay in so i can drill a hole
I have a power tool switch replacement part I need to use as just an on/off trigger. How do I wire...
(More)
I have a power tool switch replacement part I need to use as just an on/off trigger. How do I wire it up? There are six connection points on the back?
led lights does not light up and battery does not charge. Previous answer says there is a...
(More)
led lights does not light up and battery does not charge. Previous answer says there is a fuse...Upon going inside I found there is no replaceable fuse only a circuit board. Can the charger be fixed or is there a replacemencharger availiable.
The drill bit holder on my cordless drill is stuck. I blew canned air into it, then WD40, then hit...
(More)
The drill bit holder on my cordless drill is stuck. I blew canned air into it, then WD40, then hit it with a mallet. What else can I do?
