Tip & How-To about RTO Intermatic Inc Ej351c Timer Night Electronic 24 Hour
Setting Your Timer
1. Move the control lever to the OFF-CLEAR position for about 20 seconds. The red indicator light will go off and any previ- ous time settings will be cleared from memory.
Program Using "Quick" Method:
2. Move the control lever to the ON position. The Red indicator light will start fashing.
3. Rotate the time dial clockwise at least one click, stopping at the half hour nearest to the present time.
NOTE: During programming, be careful not to press the dial while turning it. If you press the dial, you will ac- cidentally set a wrong time.
4. Press the dial once to set the present time. The Red indicator light will go off.
5. Rotate the time dial clockwise to the frst desired ON time. The Red light will pulse momentarily with each click.
6. Press the dial once to enter the ON time. The light controlled by the switch timer will turn ON.
7. Rotate the time dial clockwise to the desired OFF time.
8. Press the dial once to enter the OFF time. The light controlled by the switch timer will turn OFF.
Repeat Steps 5-8 for each additional ON/OFF setting. Continue to rotate the time dial until the Red indicator light comes ON and stays ON, indicating that the switch timer is in AUTOMATIC mode
RTO Intermatic Inc Ej351c Timer Night Electronic 24 Hour Logo
We have the intermatic timer Model EJ351 and when I go to set the timer at the beginning it does not flash. It is when I start from off to on. Mary Ann
Mary Ann:
It appears that it will start flashing when you move from off to on. Here are the directions from the web site.
Gary
20 seconds. The red indicator light will go off and any previous
light will start flashing.
dial while turning it. If you press the dial, you will accidentally
set a wrong time.
light will go off.
Rotate the time dial clockwise to the first desired ON time.
AUTOMATIC mode.
Dec 02, 2010 | Solar Intermatic Ej351c Indoor Wall Switch...
intermatic ej351, i ned the instructions for resetting the timer. to turn it on at 630pm and off at 100am pleae
1) Use this procedure to automatically program, letting switch timer "record" ON/OFF activities over 24-hour period.
-Move control lever to OFF-CLEAR for about
20 seconds. Red indicator light goes off and previous
time settings are cleared.
-Move control lever to ON position. Red indicator
light starts flashing.
-At 6:30pm, manually press dial 'on' >>> then at 1:00am manually press dial 'off'
-At the end of 24-hour period, switch timer is programmed and Red indicator light will stay ON, indicating
switch timer is in AUTOMATIC mode.
2) Or you can manually program times using instructions from page 1 of manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
Sep 19, 2010 | Hardware & Accessories
There is also a way of setting it by simply turning the light on and off at the desired time. Can yu help?
Manual: http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
The manual says:
"To automatically program, letting the switch
timer "record" your ON/OFF activities over a 24-hour period,
storing them as programmed settings:
Press the dial as an ON/OFF switch to turn lights ON and OFF
at the ON and OFF times you desire for the first 24 hours.
At the end of the 24-hour period, the switch timer will be programmed
and the Red indicator light will stay ON, indicating
that the switch timer is in AUTOMATIC mode."
Sep 17, 2010 | Intermatic Programmable 24 Wall Switch...
Hello I lost my instructions for theej351c, can you help?
1. Move control lever to OFF-CLEAR for at least 5 seconds; red indicator light will go
off, and all previous time settings will be cleared from memory. (If timer fails to set, leave in off
position for 15 minutes.)
2. Move lever to ON. RED INDICATOR will start FLASHING.
3. Check a clock; then rotate time dial clockwise at least one click, stopping at the half
hour nearest to present time. NOTE: When rotating time dial, do NOT accidentally PRESS at
the same time. (While rotating dial, keep pressure, pulling out on the dial to avoid accidentally
setting an incorrect time.)
4. Press pushbutton once to enter present time. RED INDICATOR will go OFF, present
time has now been recorded.
5. Rotate time dial clockwise to desired ON time; RED light will PULSE momentarily
with each click.
6. Press pushbutton to enter ON time; controlled light(s) will turn on.
7. Rotate dial to desired OFF time.
8. Press pushbutton to enter OFF time; controlled light(s) will now be off.
9. Repeat Steps 5-8 for each addition ON/OFF period.
10. Continue to rotate time dial for at least 24 hours from the first ON time to complete
this program, at which time the RED INDICATOR light will come ON and stay ON,
indicating timer is in AUTOMATIC mode. NOTE: Dial does not rotate automatically
after setting to indicate time of day.
Oct 26, 2009 | Intermatic Programmable 24 Wall Switch...
programming
Use this procedure to manually program ON/OFF settings.
1. Move the control lever to the OFF-CLEAR position for about 20 seconds. The red indicator light will go off and any previous time settings will be cleared from memory.
1. Move the control lever to the ON position. The Red indicator light will start fashing.
2. Rotate the time dial clockwise at least one click, stopping at the half hour nearest to the present time. NOTE: During programming, be careful not to press the dial while turning it. If you press the dial, you will accidentally set a wrong time.
3. Press the dial once to set the present time. The Red indicator light will go off.
4. Rotate the time dial clockwise to the frst desired ON time.
5. The Red light will pulse momentarily with each click.
Sep 26, 2009 | RTO Intermatic Inc Ej351c Timer Night...
2,373 people viewed this tip
Top RTO Hardware & Accessories Experts
shep65_02
Level 1 Expert
Gene Haynes
Are you a RTO Hardware and Accessory Expert? Answer questions, earn points and help others
