Tip & How-To about Brother HL-2040 Laser Printer
What do the lights indicate?
LIghts on my printer link
Brother HL-2040 Laser Printer Logo
Printer connected but not printing
If your printer has a network port you should be using the network adapter.
Otherwise you want to make sure you connect the printer with a USB cable to the appropriate port on the D-Link.
Once the USB cable is connected you should be able to add the printer from your computer as a shared printer.
You will not normally see any activity lights on your router for the USB connection because it does not send or receive information the same way the LAN cables will.
I do recommend a LAN cable though as it works much better with routers. If your printer does not have one I would look into getting a network printer.
Thanks,
Pat
HP deskjet 5940 printer - lights flashing rapidly and not responding.
>flashing lights or a cobination of lights blinking on your printer will tell you exactly what the problem is, go to this link and see the steps on resoling the blinking lights on your printer
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00394958&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
2answers
my printer is just blinking on and off
Hi
Thanks for using FixYa. Please check how many times and which lights are blinking. You can then see the meaning of these blinking lights from this link--
HP Photosmart Printer Blinking lights
Please do rate the solution and revert for further assistance.
Thanks
Rylee
All lights are on
Please click on the following link and follow the document, it should resolved your issue with the printer,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00859575&cc=us&lc=en&dlc=en&product=1128296
Regards,  raj_p5983
Norman Weimar
Norman Weimar
k24674
