Have you used and abused your
LAPTOP and now you have problems that will drive you insane and spend hours up
hours of talking with tech people? Well hopefully these tips and tricks
will help you get a more stable, faster, and even a efficient working
computer running again.
1. Your Wi-Fi network is now dog-slow. If it's not a network
outage, you likely have interference. Try relocating your router to
shield it from disruptions such as microwave use or calls from a
cordless phone. Or you may be on a crowded channel. Change the channel
via your router's configuration page; look for a 'Channel' section and
try 1, 6, or 11. See "How to Improve Your Wi-Fi Network's Performance"
for more ideas.
2. Your display looks terrible. Check display settings by
right-clicking the desktop; choose Properties in XP or Personalize in
Vista, then Settings. If you can't increase resolution and color
quality, click Advanced, Adapter. If Standard VGA Adapter or another
generic adapter is listed, download a driver specific to your PC (see
How to Reinstall Windows XP for details on doing this). If your adapter
is there, try a prior driver version. In XP, click Properties, Driver,
Roll Back Driver; in Vista, open the Personalization Control Panel,
choose Display Settings, Advanced Settings, Properties, and click
Driver, Roll Back Driver.
3. Your printer is spewing out garbage. A cancelled print
job may not have cleared properly from the printer's memory. Turn the
printer off for a minute, then back on. While you're waiting, go to
Start, Printers and Faxes in XP, or Start, Printers in Vista, to delete
anything in the print queue. If the problem continues, download and
reinstall the driver.
4. Your default printer is no longer the default. Some apps, like Microsoft Onenote
install faux-printer-like devices as output options, and some will also
unhelpfully make them the default for all print jobs. Select Start,
Run, type control printers, and press <Enter>. Right-click the
printer you prefer, and click Set as Default Printer.
5. You see daily, consistent error messages citing memory problems.
To check if bad RAM is actually the trouble, download the free
MemTest86 and stick it on a boot disk; then run the full battery of
tests.
6. Your PC starts up too slowly. Click Start, Run and type msconfig.
Then click the Startup tab to see all of the apps that load at startup.
Uncheck anything you don't want to start at boot-up--but uncheck
programs one at a time, as you need many of these apps to run your PC.
(For more on pruning safely, see How to Make Windows Start Up Faster.)
7. Videos play sans audio or image.
Your codecs are probably out of date. Get multiple updates via a free
pack such as the ACE Mega CodecS Pack or the K-Lite Codec Pack.
8. You broke a key off your keyboard. If
part of the key mechanism is broken, consider scavenging an unused key
(<Insert>, perhaps) and use its mechanism with your broken key
(Apple's tutorial at PowerBook G4: Keycap Replacement will walk you
through the procedure--it should work for almost any keyboard).
Replacement keyboards for laptops can usually be found on eBay for $40
or less; many step-by-step guides show how to do the job, such as the
one for a Toshiba laptop keyboard at Laptoka.com's page, How to remove
and replace laptop keyboard yourself.
9. You bent a pin on one of your PC's ports or cables.
Using pliers will probably make things worse, but the tip of a
large-diameter mechanical pencil will fit most pins. Just slip it over
the bent pin to straighten it out.
10. Folders show only large icons.
Change the default in Windows Explorer by setting the right view on any
folder, and then click Tools, Folder Options. Click the View tab, then
Apply to All Folders (Apply to Folders in Vista).
