Tip & How-To about Siemens WFXD8400UC Front Load Washer
What to do when you get the "Drainage Blocked" message
So I had to put this tip up because it took several hours to find the problem and I was pretty frustrated until I fixed it.
Problem: The washer would not drain properly, the "Drainage Blocked" message would appear and the machine would shut down with water still in the drum.
Trouble shooting steps:
  1. Disconnect the hose from the back to see if there is something blocking it
  2. Open the pump clean out at the bottom front right of the machine and clean any debris
Those were the 2 most obvious solutions which didn't do me any good. My problem is that a piece of clothing somehow got between the metal and plastic drum and lodged itself it the drain hole. The machine would drain a little bit but not enough.
What I did:
When the pump turned on, I felt the tube coming from the drum to the pump (be sure not to electrocute yourself). The tube collapsed under the pressure so the pump on one end was working fine, but the pressure it was causing made the tube collapse because it could not flow properly. I got a little flashlight and looked inside the drum and was able to see that there was a clog. The easy fix would have been to undo the tube from the drum and clean it out. The clamp holding the 2 was positioned in a way that I couldn't reach it though. I dismantled a wire hanger and pushed it through a hole in the tub so that it pushed the blockage down a little. I then removed the clamp on the tube at the pump end and could barely see the item. I used the hanger again to grab it and could finally reach it with my fingers to get it out. Clamped the tube back on and good as new!
Tip: If your drainage tube between the pump and drum collapses when the pump starts, there is a blockage at the drum end that needs cleaning. Good luck!
Siemens WFXD8400UC Front Load Washer Logo
my washer comes on but when i hold the start button down the door does not lock and the washer wont start
If you're getting FdL or F11 codes flashing at you, the problem is in the circuit board, inside at the top back of the machine. Whirlpool seems to have poor quality control on this item. The problem is cold solder joints where the different components attach to the circuit board. The joints where the spade connectors and the relays connect to the board are thicker joints and whirlpool didn't get enough solder to flow into those joints. You can remove the board (remember where the wires go) and touchup these joints yourself or remove the board and take it to a competent appliance/tv type repair shop and they should be able to do the job. Also, the plastic enclosure for the circuit board is pretty crappy (made from the wrong grade plastic) so little tabs may break, be careful.
Oct 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water pumping in very slowly and uneven flow
The washer filling so slowly can get very irritating and frustrating..most of the time the fix is very simple. The hoses have a screen in them to catch any dirt that may come in the water and this screen plugs up.
Simply unhook the hoses at the washer and clean the screens.
This tip will explain this in more detail for you..
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
May 05, 2010 | Fisher and Paykel WL37T26D Top Load Washer
mower deck
MAKE DARN SURE THE POWER IS OFF BEFORE YOU START THE PROCEEDURE BELOW! there should be 4 connection points for this machine. Clear out your garage ... get something comfortable to lay on and a small supply of proper supply wrenches and a tape measure. put the deck in UP position. put the blades perpendicular to the front to back axis of the machine. Measure from the floor to the blade tips on the outside. record the numbers. turn the blades 90 degrees. repeat. adjust the proper corner slowly (no big changes!) continue to measure until the numbers are equal.
Low on the left - change the adjustments on the left front and back. Low in the front - lift the front - both sides.
It took me several hours to do my mower when I got it new but I was pretty particular about it
Sep 07, 2009 | Garden
I have a buzzing in my cellular phones. I took
Apparently, there was a problem with my phone line. Verizon began a fix to the problem, and it was fixed in about 24 hours. Now, I hae to somehow put the new phone system back in it's box for a return to Best Buy.
Jun 12, 2009 | Panasonic DECT 6.0 Expandable Cordless...
error code f11
F-11 is communication error between the Motor control unit and the Main CCU. Either of these or both could be bad. Sometimes unplugging all the connections from the CCU (under top panel) and plugging them back in will fix the problem. If fixed, there's a bad connection at the CCU.
Feb 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
1,977 people viewed this tip
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
