Back to:
Load Main Image Failed & Refresh Database Freezes
mikethompson
By Guru mikethompson
Rank: Guru
Rating: 86%, 291 votes
posted on Dec 15, 2007
FixYa! (100)
*** Warming : Dont try this if you dont know what your doing or if you dont know what your main problem is with the player. All the steps in this guide are collected from various sites i would not name them ( if not for you guys this guide will not be possible ) . I suggest if you dont know what you are doing is to contact sandisk technical support. ***
This is for Sansa E200 Series ( Normal and Rhapsody Model ) mp3 player with Version 1 devices. I see that many of you are experiencing this error on your players and i decided to create this guide that worked for me and for my friends players after contacting the nice guys from the sandisk technical support.
This is for Load Main Image Failed Problems.
Note : This is caused by an incorrect firmware version was loaded on the player or a bad copy of firmware files in the player.
I . For Normal Mp3 Players which dont have a Rhapsody Channel.
1. Perform Recovery mode on the player ( Enable Hold Switch + Press Record Button + Power Button ) , when it says welcome to recovery mode connect the player to the computer.
2. Open the 16MB Format which is the player in your My Computer. Then check open the Version.txt. This file will tell you what is the firmware of the player. Now you will have there,
    * .12A = Older Version firmware got to 2B
    * .15A = Also an older version of firmware go to 2B
    * .18A = Latest version of firmware. got to 2C
2B .If you have an older version of firmware downloading and updating the firwmare of player to the latest one usually resolves this problem. If not applying this file on the 16MB Format will have a greater chance of fixing the problem.
http://tinyurl.com/347j66
This file will be upgrading the firmware of you player to the latest one.
2C. Download and install this file on your computer and then run the file.
http://tinyurl.com/nwtp4
This file will be downgrading the firwmare to an older version which is .12A
II. Load Main Image failed for Rhapsody Model mp3 Player.
1. Perform recovery mode on the player. Then connect the player to the computer.
2. 16MB Format should be detected in your My Computer. Download and apply this file in the .16MB Format.
http://tinyurl.com/2z5gc5
This will correctly reinstall the correct firmware for the player.
For Players Experiencing Refresh Database on thier device. This would apply on both Rhapsody and Normal Model mp3 player.
1. Perform recovery mode on the device. Then connect to your computer.
2. The 16MB format would be recognize on the My Computer window. Download and apply this file into the 16MB Format.
http://tinyurl.com/2c5zzm
If the above link dont work just create a file name sansa.fmt take the extion of the file should be FMT. To check the file extension right-click on the file and choose properties.
=== If all else fails contact sandisk technical support.====
Thanks to crimsontide, cyber and to my special friend johnnyten for lending my your sandisk player. :D
Comment by mikethompson, posted on Dec 15, 2007
guys add a comment if this guide help with your concern.
Did you find this Tip Helpful?
Comment #1
posted on Jun 04, 2008
ruudh
By Apprentice ruudh
Rank: Apprentice
Rating: 0%, 0 votes
when i look in version.txt i just see a lot of ÿyyyy. What does this mean??
the downloaded program doesn't work, it says: failed to load version..
what am I doing wrong??
Comment #2
posted on Apr 25, 2008
gcwhite
By Apprentice gcwhite
Rank: Apprentice
Rating: 0%, 0 votes
Kick AZZ!
Comment #3
posted on Apr 17, 2008
Skillfull
By Apprentice Skillfull
Rank: Apprentice
Rating: 0%, 0 votes
hey iv got a question when i go into my "VERSION" folder i cant tell what it is. it gives me Version Info: Product Rev.: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ¢,!ûü»àè*ñ|
Base Code: ÿÿÿÿÿÿÿÿÿÿ WHAT DOES IT MEAN!!!! PLEASE HELP i dun wanna have to but another one im only 15 money dun grow on trees.
Comment by Skillfull, posted on Apr 17, 2008
ah forgot to add in my email would be better to answer my question Chriscarr25@hotmail.com please it would be help do much
Comment #4
posted on Mar 31, 2008
vna8056
By Apprentice vna8056
Rank: Apprentice
Rating: 0%, 0 votes
I have tried this three times now and nothing happened. I also tried formatting my player and emailing sansa, but they haven't helped me either. This product is a piece of junk at this point. Does anyone else have any ideas?
Comment #5
posted on Mar 29, 2008
sansalover
By Apprentice sansalover
Rank: Apprentice
Rating: 0%, 0 votes
Thank you so much!!!!!
And here i thought i had to reformat it ^^
Comment by sansalover, posted on Mar 29, 2008
You're a legend!
Comment #6
posted on Mar 22, 2008
jo mamma
By Apprentice jo mamma
Rank: Apprentice
Rating: 0%, 0 votes
u rock my socks thx buddy
Comment #7
posted on Jan 23, 2008
courtney222
By Apprentice courtney222
Rank: Apprentice
Rating: 0%, 0 votes
You totally rock. This was the most helpful thing I found and it actually solved my problem.
Thanks so much.
Comment #8
posted on Jan 15, 2008
isti82
By Apprentice isti82
Rank: Apprentice
Rating: 0%, 0 votes
You are the greatest!!
Thanx!
Can you Help with these MP3 and Digital Media Players problems?
SanDisk Sansa e250 MP3 Player
i have a sansa e250.automatic restart sansa logo only...
my mp3 player is still displaying the refresh database...
I have the sandisk sansa and when i play a song some of...
my sandisk sansa player is not showing up as removeable...
Sponsored Links
Loading problems.
Repair Service
Find MP3 and Dig. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
