Tip & How-To about Apple iPhone Cell Phones
How To Reboot an Iphone X
  • This device has a non-removable battery. This process can be used to simulate a "battery pull" when the device is unresponsive, frozen or doesn't power on.
    If your iPhone is powered on and responsive, refer to restart Soft Reset instructions.
  • For more on how to resolve power issues with your iPhone, refer to these battery troubleshooting steps.
  1. Press and quickly release the Volume up button thenpress and quickly release the Volume down button.
  2. To complete, press and hold the Side button until the Apple logo appears on the screen.
Cell Phones Logo
My lg g2 phone froze i cant turn it off it does nothing how can i unfreeze it
Hold the power button down for 5 seconds. This will perform a soft reset which simulates pulling the battery out on devices that have non-removable batteries.
Soft Reset LG G2
Dec 11, 2014 | Cell Phones
How to show images on screen
Step 1 Turn the device off, wait a few seconds, and then turn it back on again. This process will clear out any software errors that are causing the touchscreen to malfunction. If the touchscreen still doesn't work, remove the device's battery, if possible, wait ten seconds and then put it back in.
Step 2 Remove both the SIM and memory cards from the device, if the device accepts such cards, and then turn the device off and back on again. Sometimes errors in these cards can cause devices to malfunction.
Step 3 Check your device's documentation to see if there is a way to manually recalibrate the screen. This process will either be done through the "Settings" or "Tools" menus, for those devices that have an alternative method of input, or by holding a combination of buttons while you turn the device on, for those devices that only have the touchscreen for input.
Step 4 Upgrade the device's software to the latest version, if possible. Many devices come with software for your computer that will allow you to connect the device and update the software. Often, this process will resolve existing software errors that may be causing the touchscreen to stop responding.
Step 5 Clean the device's contacts and screen using isopropyl alcohol and a small brush. Turn the device off before you clean it.
Step 6 Perform a hard reset as a last resort. This reset will erase everything you have added to the device and return its software and settings to their factory defaults. Even with an unresponsive touchscreen, most devices will have a way to perform this reset either through PC software or by holding a combination of buttons while turning the device on. Consult your device documentation to determine the exact process for performing a hard reset on your device.
Step 7 Contact the manufacturer for your device if the touchscreen is still unresponsive after your troubleshooting attempts. The manufacturer may have additional steps to take that are specific to your device, and if your device is still under warranty you should be able to get a replacement through their customer service division.
Warnings
  • If you have the right tools and are willing to risk voiding your warranty, you can also open the device and scrub down the control board using the small brush and isopropyl alcohol.
  • Many manufacturers offer free telephone support, but some will charge for the service. Check your product documentation before you contact support to know if you will be charged for the service.
Required Items
  • Isopropyl alcohol
  • Small brush
References
Sep 29, 2014 | Sound Storm Laboratories SD714MB Car Video...
how to reboot htc inspire 4g phone
Hold the power button for 15-20 sec. this simulates a battery pull on a device with a non removable battery.
Aug 15, 2014 | HTC At&t Inspire 4g A9192 Cellphone...
how to remove the battery?
The battery is non removable(Internal) on the HTC One X. Press and hold the power button for 10-15 seconds(varies by model) to simulate a battery pull(work's if phone is frozen)
Jul 19, 2014 | HTC One X Android Smartphone Glamour Gray
HTC plum z100 hardreset
If the phone is frozen and you just want to "pull the battery" hold the power button for at least 10 seconds and the phone will power off(simulates a battery pull in devices with non removable batteries)
If you would like to do a factory restore(hard reset)
Ensure the device is powered off.
Press and hold the Volume Down button then press and release the Power button.
Note When the screen with the three androids appears, release the Volume down button.
Press the Volume Down button to select Factory Reset then press the Power button.
Note Allow several minutes for the reboot process to complete.
Jul 12, 2014 | HTC Cell Phones
88 people viewed this tip
Top Apple Cell Phones Experts
Ekse
jacobcheatha
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
