Tip & How-To about Heating & Cooling
Refrigeration charge
It would help to have refrigerant type.
The pressures will vary according to load, as when it is first started up. The best way is to weigh the amount of refrigerant charged. By charging by feel, can read the compressor current draw, it is safe to not exceed 1/6th of the compressor LRA. Can charge slowly by filling the evaporator to feel cold refrigerant from entrance to exit.
Condensor may fill with the bottom 1/3 cooler than the hot/warm top. Overfilling will overload the compressor, frost appears on the suction line, first portion of the evaporator may not cool off and actually be warmed.
Heating & Cooling Logo
What is a normal blood pressure range for a 91 year old woman who weighs 128 pounds
blood pressure averages vary according to the health condition of the individual
talk with your doctor and from your blood pressure history , he will advise what is average for you
Jun 27, 2017 | Health & Beauty
Wash machine - DST10146P Problem - After switch on and without any load in the drum, the kgMODE indicator appear, and the level load indicator starts blink the 10% levels from the mini to the MAX. The LED indicator (program selection buttons) starts rotating without stopping, staying in this mode permanently.
THIS MAY be your defective part!
BE VERY careful handling this switch because it's quite delicate!
1885374 "PRESSURE SWITCH" $89.68
Use THIS LINK:
http://spares.bigwarehouse.com.au/index.php?cPath=64618_64688_109010
These YOUTUBE video MAY help you!
Here is another YOUTUBE that discusses "Pressure Switches"... and that MAY be your problem. KNOW this is general information and not specific to your Hoover!
Diagnosing Washing Machine Pressure Switch Problems
How to Resolve Pressure Switch Problems in Washing Machine
Hoover and Candy Washing Machine Error Codes
TROUBLESHOOTING Link:
Dynamic Model No DST10146P 80 Product Code 31003253
Another snip-it:
..."Kg MODE Indicator". On Cotton and Synthetic cycles, during the first 4 minutes of the cycle the intelligent sensor will weigh the laundry and adjust the cycle time, water and electricity consumption accordingly. ...
More: The intelligent KG Mode sensor weighs the laundry and adjusts the cycle time, water and electricity consumption to suit the size of the load. This gives you the optimum consumption even if you are only washing one shirt.
During the first minutes of the cycle, the "Kg MODE" indicator remain on while the intelligent sensor will weigh the laundry
• Through every wash phase "Kg MODE"
allows to monitor information on the wash
load in the drum and in the first minutes
of the wash it:
- adjusts the amount of water required;
- determines the length of the wash cycle;
- controls rinsing according to the type of
fabric selected to be washed it;
- adjusts the rhythm of drum rotation for
the type of fabric being washed;
- recognizes
the presence
of lather,
increasing, if necessary, the amount of
water during rinsing;
- adjusts the spin speed according to the
load, thus avoiding any imbalance.
Dec 25, 2017 | Hoover Washing Machines
HOW DO YOU CHARGE R404 A SYSTEMS REFRIGERATION
First question, why do you need to charge the system? Second is it a remote unit or self contained. Third do you have a set of refrigeration gauges? The best wau is to weigh the proper charge into the machine through the gauges. That varies depending if you are air cooled, water cooled or remote.
Sep 23, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Operating pressures for 134A refrigerant system
I would go for 40 on the suction and 150 discharge, or divide the locked rotor current by 6 and charge so the current is 1/6 of the locked rotor current of the compressor, or by temperature/pressure relation 110* discharge and 35* suction, or get the suction line sweating. The best way is to remove all the refrigerant and then weigh the refrigerant the system is designed for on these critical charge appliances.
May 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
FREON
the backpressure or suction pressure varies with the load and the ambient temoerature of the unit. best way to make sure that your charge is correct is to pull refrigerant out and evacuate aand weight in new refrigerant with a scaloe.
Jan 10, 2009 | Amana DRB1901C Bottom Freezer Refrigerator
66 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
