Tip & How-To about Razor 300001-SL Ground Force Go Kart
Gas Engine Conversion
Just converted our Razor Kart to a 49cc gas motor. Is twice as fast as the electric version but was very unstable with the stock wheels. I went with 4" slicks and is much better. Transplanted the drive train from a pocket bike with electric start and speedometer. Was a 2 day project and was well worth the time.
Razor 300001-SL Ground Force Go Kart Logo
razor ground force go cart
I don't think this would be a problem, as long as the wheels fit the axle properly, both in diameter, and length of shaft.
Aug 24, 2014 | Razor 300001-SL Ground Force Go Kart
repair
this unit may take several hours to charge correctly
May 21, 2013 | Razor USA Razor Ground Force Drifter Go...
Razor MX650
It is the rear freewheel assembly causing the problem. if is fixable, but you have to be good with tools, the bicycle shop and the electric bike shop both said they couldn't fix it, but is is doable. 1. you need a special bmx tool that fits that back wheel, your local bike shop should have it in stock. 2. you need to remove the freewheel sprocket and disgard it along with the the bearings (make sure to unscrew the razor chain sprocket from the freewheel assembly and secure it for reuse). 3. either purchase a new freewheel sprocket for bmx wheel or remove one from a old bike (again you will a special tool for that). 4. screw the razor chair sprocket onto the new BMX sprocket (it goes on with the same 4 original screws, right over the sprockets. 5. Screw the freewheel back onto the rim now. tada its fixed.
Jun 03, 2012 | Razor MX650 Electric DirtBike
When I turn the switch on after charge, it blinks on and off and my son can not use the gas feed on the steering wheel. The power switch blinks on and off.
hi, a blinking red light ,is telling you that a battery is going bad or you have a bad plug , or your charger is going bad .
I had a razor scooter that had the blinking red light, it was a busted plug on the scooter where it plugs in.I had one scooter that had the blinking red light, it was A battery gone bad .
good luck!
Jan 29, 2011 | Razor 300001-SL Ground Force Go Kart
Razor Ground Force Go Kart will not work.
replace thumb tab throttle. part is $12.99 from razor. go to razor site to order. i had the same problem after my daughter drove it over a bumpy sidewalk.
Mar 05, 2009 | Razor 300001-SL Ground Force Go Kart
2,302 people viewed this tip
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
jasiel murphy
Are you a Razor Toy Expert? Answer questions, earn points and help others
