Tip & How-To about Samsung ML-1640 Monochrome Laser Printer
Solution to red light after refill Samsung ML 1540
Samsung printers such as ML 1640,ML 2245 and SCX 4300 have a toner page count embedded in their firmware. This is the reason that once you refill your toner after it has run out,the printer still doesnt print and says toner is exhausted. After you've refilled the cartridge,you'll have to reset the toner count also to zero...to do this,download the firmware here. ML 1640 Ml 2245 and SCX 4300 are not available on Samsung support site. You will need to google it and you may find it in torrents.
run it and it will reset your toner count to 0...you have to do this everytime you refill your toner.
Another solution is to open the backside of ML 1640 and ML 2245,locate the chip 93c66 and short pin numbers 1 and 4 and turn on the printer for a second.It only works in some cases though.
Samsung ML-1640 Monochrome Laser Printer Logo
my printer massage display toner exhied
no there is no solution to short pin, it has software solution to reset printer.
We have Zero cost solution for samsung -scx-4300, ml-2240,ML
2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Nov 04, 2009 | Samsung SCX-4300 Monochrome Laser...
toner is exhausted!! insert a new toner; this message appears while printing the page; i m talking about samsung ML1640. i have refilled the toner cartridge; but still that message appears; wat i can do now?? kindly tell
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Nov 04, 2009 | Samsung ML-1640 Monochrome Laser Printer
toner replace
reset your printer.
Jun 01, 2009 | Samsung ML-1640 Monochrome Laser Printer
I have a samsung ml 2851 nd that won't print, and says the toner cartridge is low - I replaced with cartridge 209 (which office max said would work) and it still flashes the red light and says there is only 7% toner left. Is this the wrong cartridge, or what?
The counter needs to be reset most likely. I can\t locate a reset code & steps for you. Try calling samsung and ask about the toner reset you replaced the cartridge and its still showing the count from the old cartridge.
Apr 23, 2009 | Samsung ML-2851ND Laser Printer
toner replace error
if you've refilled the cartridge,you'll have to reset the toner count also to zero...to do this,download the firmware here http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=in&CttFileID=2238869&CDCttType=FM&ModelType=N&ModelName=ML-1640&VPath=FM/200904/20090416100856890/ML-1640_V1.01.00.83.exe
The firmware for 4300 is not available on the Samsung site,you'll need to google for it.
Feb 10, 2009 | Samsung SCX-4300 Monochrome Laser...
2,927 people viewed this tip
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
