Home | All Products | 46PP9302 46 in. Rear Projection Television | Tips
Updated! Convergence Problems & Solutions - With example photos
Ecollier2012
By Guru Ecollier2012
Rank: Guru
Rating: 93%, 540 votes
posted on Aug 31, 2009
Very Helpful
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Notice the 3D look...This is a common symptom....
Your TV may also look distorted as shown below!!
In this photo blue is distorted and the video looks bent!!!
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence grid or crosshair.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move both colors in all directions your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing or you can call in a pro.
If you want to do the repair yourself check with the site www.TvRepairKits.com
They have DIY kits that include step by step photo instruction guides, original OEM convergence chips, convergence resistors, pico fuses, thermal paste, etc. Plus they will help answer any questions that you may have during the repair.
Here is a photo of a TV after the convergence has been fixed.
Was this helpful?
Yes
No
38 people thought this was helpful
Can you Help with these Projection Televisions problems?
Philips 46PP9302 46 in. Rear Projection...
I found this46pp9302 46" rear projection TV at a yard...
the green light on the front of my tv its on and off but...
blue line acroos screen that flickers
the green light on the front of my tv bilcks once then...
Sorry for the confusion, it is the input jacks that i plug...
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
