Tip & How-To about Nokia 9500 Communicator
First Windows on Symbian S60 Device
INSTALLATION GUIDE v1.1 (ENGLISH)
I. DOSBox v0.72 for Symbian by kolijoco
1. Unpack 'DOSBox_s60.rar' archiwe to your Memory Card
2. Install ALL aplication from 'Install' directory.
3. Try install DOSBox_Full.sisx
4. If show message: 'Not enought memory' install 'DOSBox_Slim.sisx' and replace previous version.
II. Windows 3.1 for Symbian (included Norton Commander 5)
1. Unpack 'Win3.1-on-s60_v1.1.rar' archive to your Memory Card.
2. Run DOSBox.
III. To switch between Windows 3.1 and Norton Commander 5.
1. Go to 'Data' directory on your Memory Card and find 'dosbox.conf' file.
2. Edit file in notepad.
2.1To run Windows 3.1
# Loader 1 -- Windows 3.1
# mount a e:\Data\win31\ (To install more drivers)*
mount c e:\Data\
mount d e:\
c:
c:\Windows\win.com
# Loader 2 -- Norton Commander 5.0
# mount c e:\Data\
# mount d e:\
# c:
# c:\nc\nc.exe
* TO install new drivers you need tu put Windows 3.1 installer files to e:\Data\win31 directory.
Edit 'dosbox.conf' file and remove '#' in 'mount a e:\Data\win31\' line.
2.2Run Norton Commander 5
# mount c e:\Data\
# mount d e:\
# c:
# c:\Windows\win.com
mount c e:\Data\
mount d e:\
c:
c:\nc\nc.exe
2.3Changed
Added MCGA (320x200) Driver
Added Win32s v1.30c with OLE
IV. Suggestions
1. To switch between the mouse and the keyboard press "Call" key.
2. Turn off automatic screen rotation, it may cause DOSBox close.
3. To change DOSBox allocated 2MB RAM edit line 'memsize=2' in file 'e:\Data\dosbox.conf'.
Nokia 9500 Communicator Logo
need to install soft ware on my laptop, but do not have a disc for lexmark x4580
Online support for Lexmark X4580:
http://support.lexmark.com/index?page=answers&startover=y&question=x4580&productCode=LEXMARK_X4580&locale=en&segment=SUPPORT&userlocale=EN_UK
Select the tab Downloads. Click the download according to the used operating system. Download now on the next page.
After the file is download click the execute file.
Files will unpack in the directory as showed while preparing the installation.
A wizard will pop up to guide you through the installation.
Guides are under the Publications tab of the support site:
pdf files:
Guide getting started
User's guide
html link:
User's guide for MAC
Sep 27, 2009 | Lexmark X4580 InkJet Printer
i have a hp laptop with windows vista home premium.i want to work on turboc++, but i am unable to do so. kindly giv your assistance.....
Install the software DOSBox ver 0.72 ( 1.2 MB ) (Freeware) from the link below.
http://prdownloads.sourceforge.net/dosbox/DOSBox0.72-win32-installer.exe?download
Before going to the details u have to create a folder (any name will do). Here we name it as Turbo
Copy the TC into the Turbo folder
Run the DOSBox 0.72 from the icon located on the desktop or from the location of the installation folder
Then u are presented with two screens which look like the command prompt in Windows
Now u are presented with two screens. One with a Z prompt. U can ignore the other screen.
There type the following commands at the command prompt [Z]:
Mount [Type in any alphabet that u wish except z] [Type the source of the turbo C] press enter
Now , Type in the following commands after the Z prompt:
Z: mount d c:\Turbo\ [The folder TC is present inside the folder Turbo]
* Now u should get a message which says: Drive D is mounted as a local directory c:\Turbo\ ***
Now type d: to shift to d: prompt .
D: cd TC [The contents inside the folder Turbo gets mounted as a virtual drive (Here D drive)
D: cd Bin
D: TC or Tc.exe [This presents u the Turbo C++3.0 screen]
On the Turbo C++ goto Options>Directories>Change the source of TC to the source directory [D] ( i.e. virtual D: refers to original c:\Turbo\ . So make the path change to something like D:\TC\include and D:\TC\lib respectively )
In order to get the full screen use the key combination of Alt and Enter
When u exit from the DosBox [precisely when u unmount the virtual drive where Turbo C++ 3.0 has been mounted] all the files u have saved or made changes in Turbo C++ 3.0 will be copied into the source directory(The directory which contains TC folder)
It is a good idea to backup your files in the source directory prior to running DOSBox 0.72
For additional help go through the readme file located in the installation folder or look on the website of the DOSBox forum.
The above procedure has been successfully implemented on Windows Vista Ultimate 64 bit
IMP : Don't use shortcut keys to perform operations in TC because they might be a shortuct key for DOSBOX also . Eg : Ctrl+F9 will exit DOSBOX rather running the code
Mar 07, 2009 | Microsoft Windows Vista Ultimate Edition
Installation of Language Interface Pack
hello
I think you need to unpack the file before you can install it.
go to that folder you downloaded the file and try to unpack the file with winzip or winrar.
then set the new unpacked location for your microsoft language installer.
good luck
Oct 13, 2008 | Computers & Internet
1,820 people viewed this tip
Top Nokia Cell Phones Experts
270rexton
270rexton
