Tip & How-To about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
How to reset to factory defaults
If you've lost the address/password information for your WAP54g, or if you've bought a used one and need to reset the configuration, follow these steps:
Step 1: Connect the power to the WAP54G. The "Act" light on the front of the unit should be on.
Step 2: Connect a network cable (cat5, normal or crossover cable is fine) from the WAP54g to your computer.
Step 3: set your computer's network interface as follows:
  • Specify an IP address manually,
  • ip: 192.168.1.2
  • netmask: 192.168.1.255 (for Linux)
  • netmask: 255.255.255.0 (for Windows)
  • default gateway: 192.168.1.1
It doesn't matter what your DNS settings are for this exercise.
** BE SURE TO NOTE WHAT YOUR OLD SETTINGS WERE, so you can reset your computer when you're done!
Step 4: On the back of the WAP54g, locate the "reset" button. Use a paperclip or the tip of a pen to press and HOLD this button for 60 seconds. Yes, really, a full 60 seconds. If you release the button before that time, just hit the reset button again, and start the 60-second timer over again.
Step 5: After 60 seconds, release the "reset" button and unplug the power connection from the WAP54G, and wait 10 seconds, then plug the power back into the WAP54G. The "Act" light on the front should light up again.
Finally, on your computer -- point a web browser at http://192.168.1.245/
It should prompt for a username and password.
  • For Internet Explorer, leave the username blank and put admin in the password
  • For Firefox and Safari, put admin in the username and admin in the password
And there you have it!
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
forgot my security passphase shirleywilt1@gmail.com
Reset and Restore the NETGEAR device to Factory Default Settings
Symptoms:
  • Forgotten/lost password to log into the NETGEAR device
  • Cannot access the NETGEAR device web interface
Resolution:
If you have changed the default password and have forgotten the password, you may need to reset the NETGEAR device to factory default settings.
When a NETGEAR device resets, it goes back to the state when it was new - all information that was entered by hand is lost! Examples include critical things you need to get online, such as ISP username, ISP password, IP addresses, wireless security keys, and ports and services that were opened. It all needs to be re-entered.
So, have your ISP information before resetting the router.
Naturally, if you moved to a new city, or if you bought a used router, the old information in the router may not be of use to you. Contact your ISP if you can't connect any computer directly to the Internet. Then, if there is a connection problem when the router is added, see No Internet Access Through the Router
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password.
    If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
For DGN2000 / DG834Gv5 Routers
To restore the factory default configuration settings when you do not know the login password or IP address, press both the Wireless button and WPS button on the side of the modem router for 5 seconds.
For FR314, FR318, and FV318
These routers require reloading the firmware in order to recover from a lost password. Download the most recent firmware from NETGEAR's Web site before proceeding. Follow the instructions in the manual.
Oct 30, 2010 | NetGear Computers & Internet
need help need help with WAP54g access point with WAP54g access point I recently had to help try to fix a small office network. Currently it has a netgear ds116 hub with a wap54g connected to the hub for wireless in the office. The wireless is not encryted. No one in the office knew the passwords and the person who set it up is gone. So i did a hard resest to restore the factory defalts. When I tried to login using 192.168.1.1 , I found that the person who set it up must have installed other firmware because I was greeted with a SONICWALL login screen and not the linksys login. I have used all the default admin/password configurations to try to get in with out success. I brought in and old WRT54gs i had lying around at home and just tried to swap in to replace the access point, but I couldn't get any data from the internet to come thru. If some could please help me instruct me on how try to fix the wap54g access point, or give me some instructions on how to configure the WRT54gs so that it will work properly it would be greatly appreciated. thanks in advance for your help
Hey !
you said that you that you reset the WAP54G , the default IP address address of WAP is 192.168.1.245.
The IP address that you tried ( 192.168.1.1 ) must be the IP addres of the sonic firewall which might be acting as a DHCP server.
To access the WAP54G set up. you will need to connect the computer to the HUB and the WPA to the hub with the cable and then try to access WPA with the IP address 192.168.1.245
Click Here for more info about Access point
Oct 07, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Setting up a WAP54G as a wireless repeater with a WRT54G
Requirements for WAP54G & WRT54G Repeater Mode function: * WRT54G: Firmware 2.02.2 or higher * WAP54G: Firmware 2.06 or higher Go to http://www.linksys.com/download to download the latest firmware upgrades for both devices. . Accessing the Router?s Setup Page: Open a Web Browser (either Internet Explorer or Netscape). 1. Type the IP Address of the Router into the Address Bar (192.168.1.1 is the default IP Address). 2. Click GO or press the [Enter] key. The User Name and Password prompt will appear. 1. Leave the User Name field blank. 2. Type admin in for the Password (the default Password). 3. Click OK or press the Enter key. The Router?s Setup page will open: * Click on the Status Tab. * Click on the Wireless sub tab. Write down the Wireless MAC Address and the Channel number values located on this page. If the Encryption Function is Disabled, go to the WAP54G Repeater Setup section below. If Encryption Function is Enabled: Note: WPA (Wi-Fi Protected Access) is not yet compatible with wireless repeater mode. You must use WEP Encryption if you wish to use security options with this configuration. To gather WEP encryption information, click on the upper Wireless tab, then the Wireless Security sub tab. Write down the Passphrase. WAP54G Repeater Setup Be sure that you have the WAP54G plugged directly into one of the WRT54G?s numbered ports for the duration of the setup. Accessing the WAP54G?s Setup Page: Open a Web Browser (either Internet Explorer or Netscape). 1. Type the IP Address of the WAP54G into the Address Bar (192.168.1.245 is the default IP address). 2. Click GO or press the Enter key. 3. The User Name and Password prompt will appear. 4. Leave the User Name blank. 5. Type in admin for the Password (the default password). 6. Click OK or press the [Enter] key. The WAP54G?s Setup page will open. 1. Set the Channel value to the same channel as the WRT54G router that was obtained from earlier steps. 2. If WEP encryption was enabled on the WRT54G: * Select Enable for the Wireless Security option. * Click on the Edit Security Settings button and enter the same Passphrase as the one of the WRT54G router that you recorded. Click Generate to populate the WEP key fields. * Click Save Settings to save your changes and close the encryption window. Click Save Settings to save your changes on the Setup page. 3. Next, click on the AP Mode tab. * Select the Wireless Repeater option. * Enter the WIRELESS Mac Address from the WRT54G that you recorded. (Disregard the fact that the page asks to ?Enter the LAN MAC ADDRESS?). Click Save Settings to save your changes. Close your web browser. You can now place the WAP54G Access Point in another nearby location (with its power adapter plugged in) so that it can repeat the wireless signal that it receives from the WRT54G. Notes: * The ?SSID? of the WAP54G does not have to be the same as the WRT54G. This can be used for initial configuration; using a different SSID will enable testing of network connectivity, and will show that the WRT54G is associated with the WAP54G. * If MAC Filtering is configured on the WRT54G, no extra configuration is needed. Wireless clients will still need to be added the MAC Filter list of the WRT54G, but the WAP54G does not have to on the list.
Feb 16, 2006 | Linksys (WRT54GC) Router
12,156 people viewed this tip
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
