Tip & How-To about Miscellaneous
Fuel Filter Replacement and Maintenance Tips
When it comes to taking care of your car, preventative maintenance is wisest. Although you'll spend money, you'll save it, too. You'll also save yourself time, frustration, and surprise roadside breakdowns. But those aren't the only reasons you should practice weekly preventative maintenance on your car practice preventative maintenance on your car.
Reason #1 is safety. Poorly maintained vehicles are less likely to protect you and your loved ones in the event of an accident. And cars that are in poor condition make it easier for you to have a mishap.
Performance is another reason to care for your car. A car that's in tip-top shape is a worry-free ride that uses fuel efficiently. It's dependable, and it handles well thanks to good tires, correct wheel alignment, and an effective suspension system. If your car's in great shape, you'll make a better deal on resale or trade-in, too. And, of course, you'll be proud to drive around in it. Like your house, your children, and your job, your car is a reflection of you. Take good care of it!
Develop the Habit of Servicing Your Car
Every three months, make it your habit to have the oil changed. Every year or every two years, ask your mechanic to check the condition of your car's filters.
Replace the Fuel Filter First
Be sure that the fuel filter is among those checked. If your car experiences power loss, starts missing, or is difficult to start, the problem is most likely a clogged filter.
The solution? Replace it.
High-mileage cars require annual fuel filter replacement. If your vehicle is driven infrequently or only travels short distances daily, it probably needs the filter replaced every two or three years. Consult your mechanic if you're unsure how often to replace the filter.
Don't Believe in "Lifetime" Filters
Many new cars are equipped with "lifetime" fuel filters that purportedly never need replacement. Although these filters are longwearing, they nevertheless will need replacement every other year. Any filter may become clogged or rusty due to moisture.
Hire a Professional
Although you can change the fuel filter yourself, you'll probably save time and money by hiring a reasonably priced auto tech to do it for you. He or she has all of the facilities and tools necessary to do the job right in a small amount of time. If you do opt to replace the filter yourself, for safety's sake, be sure no one's smoking in or near your work area.
Choose the Best Service Station
To prolong the life of your fuel filter, fill up at service stations that have filters in their pumps. These filters give fuel a final "cleaning" before it enters your car, eliminating a surprising amount of dirt and gunk that would otherwise clog your filter.
Miscellaneous Logo
this isn't really a question more a concern. My grandmother bought my brother and I a two Thunder Tumblrs. We just opened them today and realized that only one of our cars came with a battery pack.
they do that so u have to buy the other one it makes you spend money and when you spend they make more money hungry greedy take from the little people its all about money to them they want more and dont care how they get it think about it you go to the store to buy one thing stores are set up a in a way to get u to see something that u want and put words to it to make u think its on sale when its only saving u a few cents in turn u buy more spend more they make more thats why they call black friday black stores in the black are making lots of money in the red is bad that means they lost money
Aug 10, 2015 | Blue Hat Toy Company Red SPIN CAR RED 2010
Drive Slow, Save Gas?
Between 60 and 70 mph is optimal fuel use speed.
May 06, 2014 | Vehicle Parts & Accessories
Message "Engine Component Requires Sevice" comes on intermittently but gives no code.
Having a car serviced, is called preventative maintenance,
oil,spark plugs,gas filter,brakes & the like
That has nothing to do with diagnosing your concerns
Checked out, is just that. Someone that doesn't know how to
diagnose your cars problems
You need to have the problem you are concerned about, actually
looked into.
That could be time consuming & costly & may even work out
better for you at a dealership
I would prefer you start with a repair shop as it is cheaper
Bottom line is that no one actually put the effort into finding the cause
A repair shop either doesn't have a data base to learn about your
car or the skills to do the job
They are not going to spend time on something, when they
can not bill you for a lot of hours,you simply won't spend the money,
so they don't fix it
Jun 08, 2012 | 2001 Volvo S80
50 people viewed this tip
Top Miscellaneous Experts
Bill DeLisi
Bill DeLisi
Rachael Newton
Rachael Newton
Level 1 Expert
Roger Goldberger
Roger Goldberger
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
