Tip & How-To about Electronics - Others
2004 Honda Pilot Left Hand Window Controls.
Just sharing that if you change out the controller arm for the window raise and lower, and you are trying a test run of the new control arm before installation,
YOU WILL NEDD TO MAKE SURE THAT ALL, ELECTRICAL CONNECTIONS ARE HOOKED BACK UP. INCLUDING THE DOOR SAFETY PANEL LIGHT.
( No need for the speaker connection at this point).
If if you have one electrical plug not plugged back into where it came from, you will not get any action from the window motor control arm AT ALL !!!!!!
Hope this helps someone soon. Thanks goes to another user of this sight of open knowledge as he had mentioned it in a reply that I was able to read and add to I hope.
Electronics - Others Logo
How do I change rear coil spring on 2009chevy traverse
You are first going to have to support the lower control arm that the spring is mounted to. Start by removing the wheel, then disconnect the lower control arm from the knuckle/hub assembly. This should be supported with the jack. Slowly lower the jack and by doing so this will free the spring. You may have to slightly pull it out from the spring seat pocket area. Place the new spring back in the seat and have a helper slowly raised the jack while you position the arm back into position.
Jan 20, 2015 | Cars & Trucks
How do I. Get the lower control arm off my 01 stratus
SAFELY RAISE SUPPORT VECHICLE ON JACK STANDS. MAKE VECHICLE SITTING ON LEVEL SOLID GROUND. REMOVE FRONT WHEELS , REMOVE HEAT SHIELD, IF EQUIPPED WITH 15 INCH WHEELS, REMOVE BALL JOINT CLAMP NUT, REMOVE SWAY BAR TO CONTROL ARM BOLTS, REMOVE STRUT CLEVIS FROM THE LOWER CONTROL ARM, REMOVE SWAY BAR TO CROSSMEMBER BOLTS LOOSEN THEM AND ROTATE THE SWAY BAR AWAY FROM THE CONTROL ARM, LOWER CONTROL ARM FROM STEERING KNUCKLE. REMOVE BOTH LOWER CONTROL ARM BOLTS. REMOVE CONTROL ARM. DURING INSTALLATION TORQUE LOWER CONTROL ARM BOLTS 120 FT LBS. CONTROL ARM STEERING KNUCLE TORQUE NUT 70 FT LBS.TORQUE SWAY BAR BOLTS 21 FT LBS.
May 23, 2011 | Dodge Stratus Cars & Trucks
front lower control arm replacement
To remove the lower control arm raise and support your car with jack stands.Next you want to remove the wheel that you are replacing the control arm on.Remove the ball joint nut and tie rod nut.Tap the steering knuckle to break the tie rod end loose from the knuckle DO NOT HIT THE TIE ROD SO HARD YOU DAMAGE THE THREADS.If you do you will also be changing a tie rod end.Tap on the steering knuckle until your ball joint stud comes loose.Remove the 2 bolts that mount the control arm to the frame.To install the new one just go in reverse.
Mar 09, 2011 | 2006 Ford Mustang
how to fix a ball joint in a ford tempo
REMOVAL & INSTALLATION The lower ball joint is integral to the lower control assembly and cannot be serviced individually. Any movement of the lower ball joint detected as a result of inspection requires replacement of the lower control arm assembly.
  1. Raise and safely support the vehicle.
  2. Remove the wheel and tire assembly.
  3. Remove the nut and bolt securing the ball joint to the steering knuckle.
  4. Remove the nut and bolt securing the control arm to the vehicle sub frame. To install:
  5. Install the control arm assembly to the vehicle sub-frame using the nut and bolt. Tighten the nut to 69-86 ft. lbs. (93-117 Nm).
  6. Install the lower ball joint into the steering knuckle and secure it with the nut and bolt. Tighten the nut to 32-43 ft. lbs. (43-59 Nm).
  7. Install the wheel and tire assembly and lower the vehicle.
  8. Road test the vehicle.
Nov 06, 2010 | 1990 Ford Tempo
71 people viewed this tip
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
