Tip & How-To about Sony Playstation 3 (PS3) Console
Playstation 3, solve blank screen with av cable
Hi everybody, i have seen alot of questions on here that refer to people getting blank screens (no signal) when turning on their ps3 (usually after using it with a HDMI cable but not always) if you are using a standard AV cable (scart or the red/white/yellow leads) and you dont get a picture most of the time all you need to do is
1, Turn on your console at the back so the res standby light comes on
2, Hold down the on/off button on the front for several seconds untill you hear the single beep followed by another single beep then release to reset video settings to default
3, If this did not work, when on standby, hold down the on/off button but when it double beeps do not let go, just keep holding until it switches off then do the same again this time it will double beep when you hear this let go, you will need to plug you pad in with the usb cable to continue.
Hope this helps
Mike
Sony Playstation 3 (PS3) Console Logo
hdmi weak signal
Turn off your screen saver. The screen saver will affect the output of the HDMI in the same way it will affect the laptop screen.
Good luck.
Semper Fi,
Z
Feb 27, 2018 | Acer Office Equipment & Supplies
when ps3 is turned on the screen remains blank? something happens because the message on the screen "no input" disappears but the main menu never comes up.
You can try to hook up your PS3 to a different output and if it does the same, you have to replace your cable connecting your PS3 to your video output device. It is saying no signal because your output device might not been able to detect the video signal your PS3 it sending due to a bad cable. Hope it works.
May 09, 2010 | Sony Playstation 3 (PS3) Console
My screen stays blank when I turn on. Lights blue and green come on but screen stays blue
If your display settings aren't set to automatic this can occur. Example: if you have set resolution to 1080i and are trying to play it on a display that has 1080p you will get a blank screen or no signal message. you will have to connect your PS3 to the last display you had an image on and change the "display setting" to "automatic" for your PS3 to work on all displays. when you choose a specific resolution to the "display settings" it will only work on that specific resolution. hope this helps.
Feb 15, 2010 | Sony Playstation 3 (PS3) Console
NTSC -> PAL converter: would it help my prob with my PS3?
You'll need to buy the converter. Ebay usually has them for the best price around. If you wanna keep the hdmi they're usually around $200 for the converter. You could save yourself a bit of trouble depending on your situation by just selling your pal ps3 and getting an ntsc version instead.
Let me know if you have more questions.
Best of Luck!
Feb 25, 2009 | Sony PlayStation® 3 (60 GB) Console
340 people viewed this tip
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
