Tip & How-To about Miscellaneous
How to Clean and Sterilize Baby Bottles?
How to clean baby bottles after each use
It is mandatory that the bottles, lids and other pieces of equipment that are used to prepare the feed for the baby should be regularly cleaned before and after use.
  1. As fast as your baby finished the food, it is recommended to wash the bottle, its lid in lukewarm water.
  2. As for milk bottles, we suggest you to use a brush to clean the bottle and make sure the bottle doesn't leave any dried milk that usually gets stuck inside the bottle and the cap.
  3. Whenever you are finished with the cleaning process, again rinse it well with water and allow it to dry in air for some time.
This detailed process of cleaning is absolutely necessary to make sure there are no traces of milk left inside the bottle. But unfortunately, in spite of this cleaning, it is not ensured that the bottle is germ free completely.
Cleaning baby bottles in the dishwasher
When you are using a dishwasher and if you clean the bottles in the hottest water setting, it is believed that the sterilization process is effective.
  1. First, all the bottle parts should be separated
  2. All the bottle parts should be cleaned and rinsed properly to get rid of dried milk left inside the bottles.
  3. Keeping in mind that the items should not fall at the bottom of the dishwasher, all the small parts of the bottle like vents, *******, lid etc should be kept in a dishwasher safe bowl.
  4. It is recommended to run the dishwasher in sanitizing mode for better results.
  5. To make the things dry after a wash, empty the dishwasher bowl and place all the parts including the bottle in a clean cloth to make it dry.
Sterilizing baby bottles by Boiling
By using the boiling process it is ensured that no germs are left over in the bottle, by raising the temperature to high level.
  1. After cleaning, place the bottles and its parts in a separate saucepan (kept exclusively for baby bottle cleaning propose) over the stove burner.
  2. To ensure no air bubbles will be found, add enough quantity of water in the saucepan to cover the bottles and the parts of bottles.
  3. Quickly boil the water in a high temp for 5-6 mins. Over boiling baby bottles should be avoided.
  4. Turn the gas stove off and give time to the water to get sufficiently cool.
  5. Next clean and disinfect the area where you are about to keep the bottles and wash your hands before handling the bottle.
  6. Pick the bottles from the saucepan and shake it well to drain out the excess water.
  7. If you are not planning to use the bottles within next 24 hrs, put the cap and lid into the bottle and keep it in a separate container in the refrigerator.
  8. When planning for use after 24 hrs, boil the bottle and parts again before using it for the baby
Sterilizing baby bottles with Chemicals
The next process is sterilization by the chemical process. The chemical sterilizers come in the form of liquid or tablet which we need to dilute in water while sterilizing to make the disinfection process of bottles perfect.
  1. Before starting, do follow the instructions given by the manufacturers of the chemical sterilizers to prepare the sterilizing solution.
  2. Make the bottle and its parts separate and place those in the sterilizing solution. Bottle and its parts should be in a position that it remains under the sterilizing solution so that no air bubbles form.
  3. Keep the equipment pieces in the solution for the required amount of time of app. 30-35 mins (check manufacturers instruction for the time)
  4. Now, pick the bottle and its parts from the solution and drain them.
  5. You should not rinse the sterilizing solution as there is a chance of germs to get exposed again.
  6. Then clean the bottle and all equipment in soapy warm water and let it dry.
N.B. Dispose the solution after 24 hrs of use.
Source: https://www.newmomstuff.com
Miscellaneous Logo
Evolis Zenius card printer is stuck at the mandatory cleaning cycle. Is there anyway to get around this mandatory cleaning so I can print until the cleaner pack arrives?
The printer should have had 1 cleaning card packed with the driver disk and warranty pamphlet when it arrived new. If you've not used it yet, that's the first thing I'd check.
If you have just a few cards to print, you can click through the cleaning warning (unless you've already done this for 200 cards beyond the 1,000-card cleaning requirement?) and continue printing.
If your printer is still under warranty, then you should avoid the temptation for other shortcuts or circumventions - the print-head warranty is invalidated if you go beyond the required cleaning interval by too much. A replacement print-head has a list price north of 500 USD - generally not worth the risk if you can hold on a couple of days.
Oct 25, 2017 | Evolis Office Equipment & Supplies
Do you know the process to get electric baby bottle sterilizer?
Google: electric baby bottle sterilizer
Dozens of products out there
Apr 25, 2017 | The Baby Care
I need directions for using this product to sterilize baby bottles
The American Academy of Pediatrics recommends that a baby bottle be washed after every feeding with hot water and soap, then allowed to dry thoroughly. ... While your mother and grandmother may have used boiling water to sterilize baby bottles, doctors say there is no longer a need to do this.
May 03, 2016 | Babies R Us 1011187 Babies R Us Purely...
ive brought a avent streliser but threw thin instuctions away i dont know how long to strelise the baby bottles for in the microwave
I googled it, here's what I found from e-how. Hope works for you.
Avent Bottle Sterilizer Instructions
By Christine Lehman, eHow Contributor
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Many parents like to sterilize their baby's bottles before use. Avent makes baby feeding equipment including bottles, nipples and breast pumps. They also make steam sterilizers that can be used to sterilize these items before use.
The Sterilizer
1. It is important to be familiar with the components of the Avent sterilizer before operating it. The base of the unit has a stem on which the racks holding the bottles (or other things to be sterilized) are placed. The bottom rack slides on the stem and lies near the bottom of the unit. It is made of mesh and will allow steam to rise through it while keeping the contents on the rack. Three other racks are available: two flat mesh racks (which look just like the bottom rack) and a rack with rings to hold bottles in place. Spacers are placed on the stem to separate the racks. If you wish to have more room between the racks, simply use more spacers. A lid fits over the entire unit.
Sterilizer Use
2. To use the sterilizer, the reservoir first needs to be filled with 90 milliliters of water. Using exactly this amount is important because if you use less your sterilizer may not work properly, and if you use more the cycle will take much longer than normal. There is a line in the reservoir marked "max" that should remain at or below the water line. You can use the milliliter marks on one of your Avent bottles to measure this volume exactly. Once the water is in the reservoir, assemble the baskets in whichever configuration suits your needs (for example, use only the mesh separators if you are sterilizing your breast pump and use the bottle rings to stand any bottles up that you are sterilizing) and load them into the unit. If you have small items to sterilize, also sterilize the pair of tongs that comes with the unit. Place the lid on the sterilizer. Plug the cord into the sterilizing unit, then into the wall. Turn the Avent sterilizer on and wait for it to cycle. Although the duration of the cycle will vary from load to load (small loads take longer to sterilize), this should take approximately 8 minutes.
After Sterilization
3. Wait 3 minutes once the cycle is over before opening the Avent sterilizer. Before then, the unit is extremely hot and the steam could burn your skin. In the meantime, unplug the unit and wash your hands. Remove the lid carefully and begin removing the items from the sterilizer, using the sterilized tongs if necessary. If you do not remove the lid immediately, the items in the sterilizer will remain sterile for up to 3 hours after the cycle is complete. Once the sterilizer is empty, pour the remaining water out of the reservoir.
Dec 18, 2010 | Microwave Ovens
how do you clean the baby pro bottle warmer?
Ice container, measuring containers, and baskets: Dishwasher-safe (top rack only).
Measuring containers should be placed in a dishwasher basket. Or wash in warm water
using mild liquid soap. Rinse with clear water.
Bottle Warmer unit and removable cooler: Always turn OFF and unplug before cleaning.
Wipe surface of unit as well as inside of cooler and cooler lid, and inside of warming
chamber with a damp cloth or sponge using mild liquid soap. Wipe with clear water. Air dry.
Do not immerse in water. Do not use scouring pads, solvents, or abrasive cleaners, as
these could damage the unit.
Warming chamber (optional): Mineral deposits (usually white in color) may form on the
inner surfaces of the warming chamber and can cause damage to the unit. To remove them:
1. Unplug the unit.
2. Remove the basket, and wash separately as indicated above.
3. Pour 2 oz. vinegar into the warming chamber and let it stand for an hour or two (longer if
necessary).
4. Pour out the vinegar and rinse the chamber two or three times by pouring in, then
emptying out, 3 or 4 oz. of plain tap water. Do not immerse the Bottle Warmer in water.
Wipe dry or air dry.
Aug 21, 2010 | Avent Philips iQ Bottle Warmer without...
68 people viewed this tip
Top Miscellaneous Experts
Bill DeLisi
Bill DeLisi
Rachael Newton
Rachael Newton
Level 1 Expert
Roger Goldberger
Roger Goldberger
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
