Tip & How-To about Nintendo 64 Console
Be careful when purchasing N64 games on ebay
China has been producing rip offs of some of the most expensive game cartridges. Check for logos on the back of the cartridges in the images to make sure what you're buying is legit. Especially if it's a pricier game like Conker's bad fur day.
Nintendo 64 Console Logo
WWE '12 [PC-Windows Full Game] Full Rip password
what is the password of WWE '12 [PC-Windows Full Game] Full Rip
May 31, 2012 | Video Game Consoles & Games
ive turned on the game but no response.it only says gameboy ,but the nintendo logo does not pop up leaving only a blank screen that says gameboy.
The Nintendo logo not showing up but the GameBoy one does means that it can't detect the game. Take the cartridge out and put it back in again. If that doesn't work, clean the contacts on the cartridge. As a temporary fix, you can blow into the cartridge (the bottom where the shiny metal lines on the board are) or you can clean the cartridge by using some rubbing alcohol with q-tips to wipe the metal contacts on the cartridge to clean it and let it dry for an hour.
Jul 06, 2011 | Nintendo Pokemon Emerald for Game Boy...
How to remove the cause of a black line a HP Laser Jet printer model 4250 has produced down the center of everything printed for a long time? Thorough cleaning has had a very little effect.Last week I asked the same question but provided the incorrect Model #. HP says the only fix is a approx.$300.00 kit. Is that true? If so that is a big expense for a Non-profit!
In cases of print quality issues you should always start with the imaging drum. In this case the toner cartridge. Make sure it is not a re-manufactured or refurbished toner cartridge. A lot of times when someone refurbishes the cartridge they don't replace the imaging drum (the blueish green drum under the shutter). Check for toner stuck or burned on the drum. If there is you need to replace the toner cartridge
If there is no toner stuck or burned on the imaging drum then you more than likely you will need to check or replace the Fuser in the back of the machine. The back door of the machine comes out easily enough and the fuser clips into place. **Be careful it doing to be hot.** Remove the fuser and check the rollers inside for burned toner or damage. If so replace the fuser .
You can purchase a Fuser Kit from HP or find a refurbished fuser from Depot America or OrionMarket.com for a lot less.
Aug 16, 2010 | HP Office Equipment & Supplies
158 people viewed this tip
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
shevantha perera
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
