Tip & How-To about Miscellaneous
APPLE iPHONE 6 PLUS GOING HAYWIRE
My Iphone 6 plus was going crazy I think it's called ghosting when it does things without me touching it and when I do it goes nuts here's what I found out and used to cure it, so far this has been successful for two weeks.
open your iphone using online instructions
you will need an opening kit Amazon do them inc a suction cup. a pentelope screwdriver a lever a cross screwdriver also black electrical tape,
open as instructed careful to prize it on the rim, rest the screen open against a folded towel no need to remove it completely,
unscrew the five cross screws holding the display assembly cable, it's a metal plate with 5 screws these are all different sizes I used an address label with the ends folded down onto a sheet of paper with the sticky side up and wrote 1 to 5 around it place the screws on the label to hold and replace in the sequence you choose.
cut a piece of tape to fit the back of the metal plate trim around edges poke a needle through the holes to allow the screws easy access.
replace the metal plate.
close the phone, replace the screws, this works due to the metal plate originally not having a firm hold causing overheating on the cables causing the erratic screen,
I found this tip online on MacRumors posted by Mdsune, and it worked so well I am passing it on.... hope it helps :)
Miscellaneous Logo
the touch screen on my iphone 6
Hi Lance,
Is your touch screen not working?
Hold down the power and home button until you see the apple logo.
If that does not work please answer these questions: does the screen light up? Does the home button work, and lastly, does the finger print reader work?
I’m happy to assist further over the phone at https://www.6ya.com/expert/sam_202544c4a4c23322
May 03, 2016 | Apple iPhone 6
How can I recover my contacts for my iPhone 3
Do you have backups from your lost iPhone 4?
If not, take a look at this guide about recovering iPhone contacts without backup.
How to Recover Deleted Contacts from iPhone without Backup
Sep 14, 2014 | Apple iPhone 3G
lost my contacts 200 on sim and 200 plus on phone. Any recovery
STOP! Don't try to recover your contacts yourself. You could make matters worse. Take your phone to a repair facility owned by your cellular provider. Many have software that can recover lost contacts. I've run into this before on other phones and taking your phone to a service center is your best bet. Good luck.
Jan 25, 2011 | Nokia 3110 Cellular Phone
122 people viewed this tip
Top Miscellaneous Experts
smelborp
Level 1 Expert
david jackson
Level 1 Expert
jumon
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
