Tip & How-To about Miscellaneous
How to get to end of a MS Word document on a Mac
I missed the "Home", "End" and "Page up" and "Page down" keys on a PC.
To get to the end of a MS Word document on a Mac hold down the "Function" and "Option" keys and depress "right arrow" key. I find this very helpful with long documents.
Haidee
Miscellaneous Logo
ctrl home & ctrl end key laptop
try using just home or end. Not ctrl
May 20, 2013 | Sony VAIO Computers & Internet
burn windows 7 iso for hp laptop to dvd
OLD DV6910. note book. (circa 2007 ) near end of HP support.!
MS stopped VISTA this spring.
no, toshiba is no good, as are all other PCs makers disks no good. your PC us USA HP computer, its not from Japan.
sorry. only MS disks or best of best HP disks work.
the ISO from MS, how'd you get that, and when.?
the current link at MS needs valid RETAIL COA code to download it.(oem codes not)
The MS disk do not have all drivers need, to make an HP pc run..
sure it will load, but many things CAN be dead.
is your F11 restore dead too? (its VISTA, if you dont know)
power on , F11, f11, f11, f11 , hammer it. see the HP restore?
here is your official HP support page.'
https://support.hp.com/us-en/product/HP-Pavilion-dv6900-Entertainment-Notebook-PC-series/3725196/model/3740554
see? that
and all were shipped with VISTA, and F11 key restores
VISTA , there is no W7 drivers. from HP , zero
"i got image to burn.?"
so then what?, did you install W7?
and see all those dead chips? in device manager
did you get Ethernet working first so W7 can PNP the drivers automatically, /??
Things that can fail are.
HP special drivers for like , hot keys, that MS does not have
all HP apps will be missing.
and all drivers for old vista chips not supported under w7
see?>
MS loads. here is the path (using ms, disk and not HP media kit)
why not get the HP kit from HP???????
  1. Get MS w7 ISO, from MS using the $120 key, COA key,
  2. oops the HP key is no good, its OEM key/.
  3. down load ISO from MS.
  4. burn a USB stick or DVD from ISO, (Rufus, or imgburn free)
  5. boot PC using BIOS boot to DVD or stick as the case applies.
  6. W7 Loads, ok. (it runs sure, but...)
  7. W7 fails on Ethernet or wifi, one must work now or doomed, lacking other PC to find drivers from chip makers or MS.
  8. I wire up the Ethernet jack RJ45 cat 5 to my router.
  9. the internet is connected, i then let W7 find the drivers, good luck finding them all.. some can be missing, on 10 year old LT.
  10. if at wits end see this , on how to get them the HARD way.
  11. http://www.pcdied.com/Drivers.html
if you make a PCI scanner boot disk (or stick)
http://www.pcdied.com/pci-101.html
you can find most drivers. (mine never fails)
using he scanner on any PC we see all chips
and with vista drivers failing on w7
we go to the makers site and get the W7 driver
as seen here, PCI sniffer3 , I uses this all the time.
for exactly this reason.
the HP media kit DVD set is for VISTA only.
sorry.
Aug 12, 2017 | HP Pavilion Computers & Internet
Is there a key combination for the ACER Aspire 5734Z-4725 that will do "page up", "page down" and Home and end? I tried number lock and it seems like that just gives me the arrow control again. I don't need that AGAIN! I need home, end, page up, page down. Any ideas?
Yes you press NumLock buttom localized superior left on the keyboard and the you can press Home (number 7 button), End (number 1 button), Page Up (number 9 button) or Page down (number 3 button)
Nov 16, 2010 | Acer Aspire 5315 Notebook
where is the scroll lock key?
most likely the scroll lock key is accessed by the fn key on the keyboard, it will be in different colors probably on the page up page down end home buttons.
Mar 20, 2010 | Dell Inspiron Mini 10 Notebook
292 people viewed this tip
Top Miscellaneous Experts
Bill DeLisi
Bill DeLisi
Philippe Dekyvere
NAOMI Braine
NAOMI Braine
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
