Tip & How-To about Washing Machines
How to keep your washer for more than five years and without a bad smell
The smell is from using to much detergent you shouldn't use more than two tablespoons,it coats everything inside the washer and builds up from using to much of it,if you take it apart and look at the drain hose you'll see that the hose was once white and now it's black coated with stinky detergent,or pull out the drain hose out of the stand pipe and rub your finger in the pipe or on the drain hose part that was stuck inside the pipe,most are covered with detergent,it coats the spider gear and eats at it like acid,it's made of soft metal,use two tablespoons and you won't have any problems,another way to check is start your washer and fill it with no clothes or soap,let it agitate for like five minutes,if you see foam in the water from the extra soap you've been adding you know you've been using to much
Appliance Parts Pros" advises that most basket spider corrosion and subsequent breakage is a result of using too much detergent combined with hard water. The site recommends using no more than a quarter cup of high-efficiency detergent and using water with a softness level of no more than two grains. Following these recommendations should result in a basket spider life expectancy of 12 to 15 years.
i use my finger as a guide,stick your index finger along side of the soap cup and draw a line don't fill it over that and you won't have any stinks or worry about damaging the spider gear.hope this helps whoever reads it
Washing Machines Logo
smells very bad inside washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} A lot of machines can suffer from this problem. It is usually down to a bacteria build up between the drum and the tub. The majority of appliances that suffer form this have been used mainly on 40 degree washes and with a biological detergent.
The best way to get rid of this smell is to place two tablespoons of washing soda or soda crystals in the detergent drawer and then run the appliance empty on the 90 degree wash. You may have to repeat this treatment several times before the smell goes but it will go eventually.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
Jan 20, 2010 | Speed Queen CTSA0AWN Front Load Washer
washer has ordor
run a cycle with a heathy amount of bleach on hot. Odor is usually due to bacteria or somehting left behind. Is there any filter that can be cleaned??
Jer
Jan 16, 2010 | Kenmore HE2 Plus Front Load Washer
my front load washer is making the laundry room smell with a really bad oder, why & what can I do to fix it?
Non HE detergent will cause your front load washer to have odors. If you do use HE detergent and still have the problem,use the "AFFRESH" product in the washer to neutralize the odor.
Oct 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
240 people viewed this tip
Top Washing Machines Experts
Marvin
Marvin
