Tip & How-To about Miscellaneous
Repair; general (anything)
Remember: the easiest solution is usually the correct one. think about the last thing that was touched or changed. look here for the resolution of your issue first. don't be led down the primrose path of complicated solutions. always check the easiest solutions first e.g. fluid levels, switch positions etc. you will learn with experience that the simple solution solves 90% of problems.
Miscellaneous Logo
adjust the video height on MAG lt716s computer monitor
don't worry overly, the shapes of things will be altered as you change the resolution. The main preset resolution s have different
aspect ratios
1920 x 1080 is 1.77/1
1600 x 1200 is 1.33/1
you change aspect ration according to your selected resolution.
Your monitor will have a native resolution at which everything looks normal, .......If you vary from that resolution things will obviously change.
Jul 16, 2015 | Computers & Internet
Several times each day my mouse on my laptop (Dell Lattitude E5510) becomes unresponsive. I can then use the touch pad to restore my control or the mouse works if I switch USB ports. It doesn't se
Some mouses stop responding if you do not use it for a few minutes. This is usually a battery saving feature. Usually all you got to do is use the scroll button to reactivate the mouse by scrolling up or down. This will bring the mouse back to life. When you change the ports you are actually doing the same thing (reactivating). Also check whether battery needs changing.
Mar 01, 2012 | Computers & Internet
hi, my problem is that i can run my pc only in safe mode and if i try to use it in the normal way the monitor tunrs black and the blue light starts blinking, i can't configure it with the resolution 1920X1080 because my pc doesn't support it, is that the reason of my problem? thanks
This usually happens when your computer is set to a resolution that the monitor does not support. I have seen it when I set the resolution too high. That's why windows asks you to confirm the new mode after is switches to a new mode.
I think that in safe mode, you can set your 'normal' resolution. Try setting it to 1024x768 or something. If this helps you can try to find a resolution that works for your monitor. If -after a resolution change- your monitor goes dark: Don't touch the keyboard. Windows should switch back after about 10 seconds.
Jan 02, 2010 | Samsung 2333SW 23" Widescreen DVI LCD...
the screen is off center. How to I move it to the right?
Try changing the screen resolution and then back. This should fix it.
Mar 06, 2009 | Acer Aspire 5630 Notebook
hi there i cant remember how to change the resolution to 1080 it is on 480 and i would like to change it i have a 62" mitsubishi can you help
usually the set will sense the resolution and change itself. the format button on the remote changes the screen size
Jan 04, 2009 | Mitsubishi WD-62525 62" Rear Projection...
116 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
