Tip & How-To about Humidifiers
How to clean a Vick's Humdifier
Pour a cup or two of undiluted vinegar into the tray and allow it to set undisturbed for 20 to 30 minutes. The vinegar loosens scale deposits water leaves behind. For models V400 and V3900, dampen a cloth or sponge with straight vinegar, then wipe out the inside of the base to remove scale. Rinse with warm water.
Humidifiers Logo
how to clean sunbeam humidifier swm5250
CLEANING AND MAINTENANCE INSTRUCTIONS (from the manual):
The following maintenance procedures must be routinely followed in order to ensure proper, efficient operation of your humidifier. The unit WILL NOT WORK CORRECTLY if it is not cleaned properly.
When the unit is in use, daily and weekly maintenance is recommended. Regular weekly cleaning prevents scale buildup on the heating element and base. It also prevents micro-organisms from growing on the base. This ensures that maximum efficiency will be achieved.
We cannot over-emphasize how essential proper cleaning is to the maintenance and continued use of your unit and to the the avoidance of algae or bacteria build-up.
DAILY MAINTENANCE
Allow to cool before maintenance.
1. Before cleaning, set the control to OFF (O) position and unplug the unit from the electrical outlet.
2. Remove the water tank then unlock the misting chamber by rotating the safety lock towards the front of the unit. Lift mist chamber from the unit's base.
3. Empty water and minerals from the base and place in the top rack of the dishwasher. This will remove any sediment and dirt that has accumulated in the base.
NOTE: It is imperative that the base is cleaned properly. The base is dishwasher safe (top rack ONLY) for easy cleaning.
4. Wipe the heating element clean with a soft cloth after it has had a chance to cool.
5. Replace misting chamber and engage safety lock. The Electronic Thermal Control Heating element is lined with a coating that is designed to provide the easiest cleaning and prolong the operating efficiency of the humidifier. DO NOT use any metal or hard objects to clean the Heating Element. Never use detergents, gasoline, kerosene, glass cleaner, furniture polish, paint thinner or other household solvents to clean any part of the humidifier.
WEEKLY MAINTENANCE
Remove Scale: Allow to cool before maintenance.
1. Repeat steps 1-5 in the Daily Maintenance section.
2. Clean the tray by partially filling the base with one 8 oz. cup of undiluted white vinegar. Let solution stand 20 minutes, cleaning all interior surfaces with a soft brush. Dampen a cloth with undiluted white vinegar and wipe out entire base to remove scale.
3. Rinse with clean warm water to remove scale and the white vinegar solution before beginning to disinfect the tank.
Disinfect Tank:
1. Fill tank with 1/2 teaspoon of chlorine bleach and 1/2 gallon of water.
2. Let the solution stand for 20 minutes, swishing every few minutes. Wet all surfaces.
3. Empty the tank after 20 minutes, and rinse well with water until the bleach smell is gone. Dry with a clean cloth of paper towel.
4. Refill the water tank with cool water; replace the housing and water tank. Repeal ALL Operating Instructions.
Jan 22, 2012 | Sunbeam Humidifiers
Cleaning water tray
I usually just balance the tray upside down on top of the base and fill the edges with vinegar. You could also put the the tray in a bowl filled with vinegar and submerge the whole thing.
Dec 19, 2008 | Honeywell HWM-450 4 Gallon Humidifier
cleaning
For Model V745A Vicks Warm Mist Humidifier:
Weekly Maintenance (Removing Scale)
  1. Turn the switch to off and unplug the corn from the wall.
  2. Remove Water Tank and empty any remaining water from the water tank.
  3. Remove Medicine Cup from the Cooling chamber from the Base. Carefully remove the Cooling Chamber and Removable Water Tray from the Base.
  4. Soak the Removable Water Tray in a solution of white vinegar and water for 20 minutes. Rinse thoroughly and then wipe dry with a soft clean cloth.
  5. Fill the heating chamber with undiluted white vinegar. Let stand for 20 minutes. Dampen soft, clean cloth or sponge with undiluted white vinegar and wipe out Heating chamber to remove scale. DO NOT use soap, detergents or abrasive cleaners.
  6. Rinse the Heating Chamber using clean warm water, being careful not to submerge the base in water.
  7. The Water Tray, medicine Cup, and Cooling Chamber are top shelf dishwasher safe.
May 23, 2008 | Vicks Warm Mist V745A 1 Gallon Humidifier
Humidifier does not reset
According to Holmes, one of the causes of the Reset light staying on is scale buildup on the heating element.
2. Clean the base by partially filling the base with one
8-oz cup of undiluted white vinegar. Let solution stand
the tank.
it has had chance to cool.
If the scale has really built up it might take longer than 20 mins for the vinegar to get rid of it and you might need to refresh with new vinegar.
Your Manual can be found at this link:
http://www.holmesproducts.com/Manuals/Holmes/HM5250-UC_English.pdf
Good Luck.
Apr 07, 2008 | Holmes Products HM5250-UC Humidifier
need to clean the filter
http://homeappliance.manualsonline.com/manuals/mfg/vicks/v3100.html
This is the link to your manual.
Daily Maintenance
1.
Turn switch to OFF position and unplug the cord from wall outlet.
2. Lift the Water Tank from Base. Carefully remove the Water Tray from the base being
careful not to damage the delicate Wicking Filter. Empty excess water from the Water Tray
without removing the Wicking Filter. Remove the Tank Cap and drain any water from the
Water Tank. Rinse the Water Tank with lukewarm water after each use. Wipe accessible
surfaces of the Water Tank and Water Tray clean with a soft, damp cloth.
3. Do not immerse the Base in water. For storage, wipe dry with a soft, clean cloth. Keep
water away from the Air Outlet.
4. Do not leave water in the Water Tank or Water Tray when unit is not in use as it may
result in the build up of mineral deposits and bacteria that can inhibit the output
efficiency of the humidifier. Please note that if water remains in the Water Tank for more
than a day or two, bacterial growth is possible.
5. Replace Water Tray with Wicking Filter. Then replace the Tank. Humidifier is now ready for
use.
Weekly Maintenance
Removing Scale
1.
Remove the Water Tank and empty any remaining water from the Water Tank.
2. Turn switch to the ON position, either low or high speed, and operate Humidifier until the
Wicking Filter is thoroughly dry.
3. Turn switch to the OFF position and unplug the cord from wall outlet.
4. Remove Wicking Filter from the Water Tray by carefully lifting straight up taking care not to
tear filter.
5. Remove the Water Tray from the Base. Fill Water Tray with undiluted white vinegar. Let
6. Dampen soft, clean cloth or sponge with undiluted white vinegar and wipe out Water Tray
to remove scale. Do not use soap, detergents or abrasive cleaners.
7. Rinse the Water Tray thoroughly in clean warm water or put in top shelf of dishwasher to
remove scale and vinegar before disinfecting the Water Tray.
Disinfecting the Water Tray and Tank
1.
Fill tank with 1 teaspoon of household bleach in 1 gallon of water. Let stand twenty (20)
minutes, shaking vigorously every few minutes, drain and rinse with clean water until the
bleach smell is gone. Dry with a clean cloth or paper towel.
2. Wipe the Water Tray with a soft cloth dampened in the bleach and water solution. Rinse
the Water Tray thoroughly or place in dishwasher before proceeding.
3. Wipe all exterior surfaces of the Base with a soft, dry cloth. Do not immerse the Base in
water or use water to clean the base. An electric shock may result or the humidifier may
be damaged.
Hope this helps.
Good Luck.
Dec 01, 2007 | Vicks V3100 1.2 Gallon Humidifier
177 people viewed this tip
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
