Tip & How-To about Kyocera Office Equipment & Supplies
Printer will not print
If your network printer is struggling to succeed in the long haul, go to your search bar of you operating system. type in service and press enter. scroll down to print spool and right click stop and restart. this will help you printer if it is running slow.
Why can i notreceive the internet
You will have to open up your network connections
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled.
Make sure your antivirus program is not blocking the internet connection.
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
You only need to check the BIOS if you cant install the driver.
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"ima
Click start type cmd press enter you will be in DOS mode
type in ipconfig press enter you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
or you could download one
http://download.cnet.com/2000-20_4.html
on the homepage you will see a search bar type in the ethernet controller freeware you want/need
Sep 24, 2013 | Yahoo Mail
can not get on line
You only need to check the BIOS if you cant install the driver or you could download one
"Enabled"ima
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html
http://download.cnet.com/network-drivers/3150-2112_4-0-1-4.html
Sep 07, 2013 | Computers & Internet
I deleted my internet program and now cannot connect
What type of computer ?
"Enabled"ima
Aug 06, 2013 | Computers & Internet
network drivers missing
"Enabled"ima
Aug 06, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
where is the driver?
To download drivers for any particular model from HP website, open www.hp.com, in the search bar type the printer name and press enter.
Now select Software & driver downloads option and click on it, you can select the type of operating system and download the drivers needed.
Sep 28, 2009 | HP Office Equipment & Supplies
451 people viewed this tip
Top Kyocera Office Equipment & Supplies Experts
Marvin
Marvin
George Mclaughlin
Ed
Ed
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
